amps for roll cage
Old Mar 4, 2006 | 03:51 PM
fuzzynutz's Avatar
Default amps for roll cage
i have an econo tig 230v is that unit poererfull enough to build a roll cage with? if not what kind of amps do i need to be running
Old Mar 4, 2006 | 07:03 PM
fulldragcrx's Avatar
Default Re: amps for roll cage (fuzzynutz)
I think your ok. get small ( of the same size tubing your going to use) scrap pieces from a local fab shop and weld them together just to make sure.
Old Mar 4, 2006 | 07:41 PM
Formula Racing's Avatar
General rule is 1amp for each .001 so you should be ok
Old Mar 4, 2006 | 08:36 PM
KFMRC's Avatar
plenty if capacity for building a car
Old Mar 5, 2006 | 02:08 PM
fuzzynutz's Avatar
Default Re: (KFMRC)
thanks alot guys
tsiah
Welding / Fabrication
Apr 15, 2007 08:32 PM
KevinACrider
Feb 28, 2006 02:21 PM
Want2race
May 18, 2005 06:07 PM
EGJDM
Mar 9, 2004 12:43 PM
