1992 Honda Civic b16 Swapped $3,300 San Jose
Old Mar 4, 2006 | 02:14 PM
97Alex's Avatar
Default 1992 Honda Civic b16 Swapped $3,300 San Jose
http://www.craigslist.org/sby/car/139012686.html
$3300 firm
The drivetrain has 90k miles on it & runs well.
Clean title 4 door dx model.
Many of the body panels have dents in them & the passenger rear door has bondo thats painted over. This car was used soley as a fun commuter/beater.
Timing belt, water pump, all accessory belts & base timing replaced/adjusted less than 1,000k miles ago (have reciepts & pics of the work). Car has been smogged and is good for another 30 days. I will meet the buyer at the DMV in order to transfer the title so everything goes smoothly.
Details:
jdm b16a swapped in about 40k miles ago
5 speed manual transmission & works well (no grinds)
No power windows
No power locks
Power steering, but the pump is leaking (needs a used one swapped in)
Equipped with A/C, but it stopped blowing cold air about 2 months ago
Si cluster
New master cylinder
AEM adjustable cam gears
CTR cams
Magnaflow full exhaust
DC sports carb approved header
AEM coild air intake carb approved
Gsr front cloth seats
New front tires and rears are ok
Lowered on tokico blues & H&R's i believe
Camber kit included, but not installed
Front strut bar & rear lower brace bar.
Gsr 15" fat fives
Bad stuff:
-Car has dents hence beater.
-Paint on roof is bad
-Drivers side window regulator needs to be replaced b/c somebody recently broke into the car and bent the regulator so window doesnt wanna go down.
- Theif broke the glove box & stole the face plate for cd player and the amp (pre hooked up for amp though)
- The throttle cable LOVES to stick! I think it could need a new throttle cable because it sticks after u let off the throttle and leaves the motor running at 2krpms. DEFINATELY a throttle cable sticking problem
- Like most swapped cars i had to get this one smogged with the help of extra cash wink wink. No worries though because the car will be sold with a valid smog cert.
What it needs to get BAR'd (certified in Ca)
- USDM del sol b16 dohc ECU
- Possibly another high flow cat intstalled because these engines are notorious for high nox emissions.
- Purge valve hooked up on the TB already installed, so doesnt need this
Id be willing to trade my car + cash for your 98 honda accord, but thats it as far as trades go..
Email me so you can come check her out.
$3,300 FIRM
sodef98@hotmail.com
408-228-7245 Alex
Old Mar 5, 2006 | 10:37 AM
97Alex's Avatar
$3100 takes it today!!
Old Mar 6, 2006 | 05:13 PM
97Alex's Avatar
TTT
Sgtfluffy16
Feb 14, 2011 03:01 PM
B serious
Sep 1, 2010 06:05 AM
AllmotorGSReg
Northeast (Sales)
Aug 10, 2008 07:35 PM
beak
Oct 4, 2006 06:30 PM
97Alex
Jul 9, 2006 02:52 PM
