valve problems
Old Mar 4, 2006 | 12:27 PM
i hate rice's Avatar
Default valve problems
ok, i still CAN NOT ******* FIGURE OUT what is wrong with my car,
its not rob knock,
its coming from the head.
i changed the head,
its making the same sound
the only thing i used from my old head was the rocker arms,
i noticed they were numbered, i have 6 number 4's and 2 numbers 2's.
are the rocker arms differant or are they numbered for the expletive of it.
and it ran at one point just fine with them in so i doubt that the problem
so i adjusted the valves. it got better, but its still making that sound.
maybe i adjusted it to the wrong specs seeing how no one told me on here and i had to google it.
so A does anyone know the specs for a valve adjusted for a ZC DOHC
and B does anyone have ANY!!!! clue what else it might be!?
Old Mar 5, 2006 | 10:49 AM
Default Re: valve problems (i hate my ZC)
maybe someone should just guess. or something
my cars been down a month
i REALLY would appreciate any help whats so ever
Old Mar 5, 2006 | 10:51 AM
hondagriz
Guest
Posts: n/a
got to get a new spark plug retaining ring that should fix it..
Old Mar 5, 2006 | 11:12 AM
Default Re: (hondagriz)
im not 100% sure what thats gonna do,
did you have this problem at one point?
or was that a guess?
Old Mar 5, 2006 | 11:40 AM
Crx Jimmy's Avatar
Default Re: (i hate my ZC)
does it run fine? or does it just make a weird noise? are you sure its not the injectors clacking
Old Mar 5, 2006 | 11:46 AM
jlicrx's Avatar
Lo-Buck EF's Avatar
hows your valve adjustment? does it retain an adjustemnt?
Old Mar 5, 2006 | 01:17 PM
Default Re: (Lo-Buck EF)
i just adjusted it. it seemed ok for a second and then started acting up again i just took video and sound of it i'll post it in a minute
Old Mar 5, 2006 | 01:33 PM
ok so the site i use isnt allowing videos to uplaod right now.
i'll get before the end of the night or i'll sign up for another site haha
Old Mar 5, 2006 | 02:46 PM
Lo-Buck EF's Avatar
sounds to me like you may have a bent valve or something. sounds like a problem we had with a b16 head but we never got to fix it.
Old Mar 5, 2006 | 02:49 PM
Ak_ef9's Avatar
It still might be a bottom end knock? I had the same problem with an ls it sounded like it was the head cuz it was a light knock but it ended up being the rod bearing spun
Old Mar 5, 2006 | 03:03 PM
hatchinprogress's Avatar
Default Re: (Ak_ef9)
jilcrx comes thru again!! i say it does sound like it's valves, when you adjusted them.....did you do it when the engine was cold?? also if you need stock valves...i have my valves and springs from my dohc zc (i re-built the motor and used after-market valves/springs)
Old Mar 5, 2006 | 03:38 PM
Default Re: (hatchinprogress)
yea i let the car sit for a day and a half before i adjusted them again. and i changed the head on it and it made the EXACT same sound. but, i sed the same rocker arms, im gonna check it in the morning to see if its not adjusted the same as it was,
i really wish the video would work so i can get the sounds and **** on here
and does anyone know what a spark plug retaining ring is?
Old Mar 5, 2006 | 03:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i hate my ZC &raquo;</TD></TR><TR><TD CLASS="quote">yea i let the car sit for a day and a half before i adjusted them again. and i changed the head on it and it made the EXACT same sound. but, i sed the same rocker arms, im gonna check it in the morning to see if its not adjusted the same as it was,
and does anyone know what a spark plug retaining ring is? </TD></TR></TABLE> i dont know what a spark plug retainer is.....but you might have to pull the head and check the valves (maybe 1 is bent) did you just replace you timing belt (or did it break on you) also i have some rocker's from my other dohc zc (but you should check yours to see if theres wear) oh and on your rockers did you put them back in the same place(order) you pulled them from?? always put them back the same way you pulled them
Old Mar 5, 2006 | 03:57 PM
i pulled the head once. and replacved it with another one, and i checked the old one and none of those valves were bent.
and its not just one clacking sound, its a lot of clacking sound.
and yea i did just change the timing belt. and the tensioner, and waterpump
Old Mar 5, 2006 | 04:08 PM
Click here to watch MVI_228365
there, take a listen
Old Mar 5, 2006 | 04:12 PM
johnjw's Avatar
it really sounds like rod knock, sorry to say. or, a big or, you could have valves sticking in the open position and when you adjust them, the clearence is wrong.
but it really sounds like rod knock.
good luck
Old Mar 5, 2006 | 04:35 PM
Default Re: (johnjw)
im about to go take the oil pan off and make sure
Old Mar 5, 2006 | 05:23 PM
Ak_ef9's Avatar
check your oil pressure. If its low then its a bearing. otherwise take off the oil pan and windage tray and see if any rods can wigle back and forth. A rod will move side to side but it shoudnt move back and fourth.
Old Mar 5, 2006 | 05:28 PM
si0385.'s Avatar
when you pull the pan check for metal shavings also make sure the rods dont move from front to back like Ak_ef9 said
Old Mar 9, 2006 | 07:20 AM
Default Re: (si0385.)
the rods were fine....
im running out of options,
i really think i messed up the timing,
is it true you have you spin the motor around twice before setting it at tdc. i think thats proabably the only thing i havent dont to it.
Old Mar 9, 2006 | 12:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i hate my ZC &raquo;</TD></TR><TR><TD CLASS="quote">the rods were fine....
</TD></TR></TABLE> you rotate the crank to tdc to get it to the compression stroke (the crank rotates 720*....360* on exhaust stroke and 360* on compression stroke)
Old Mar 13, 2006 | 06:53 AM
ive tried that, and it didnt work, its making the same sound.
Old Mar 13, 2006 | 07:01 AM
jlicrx's Avatar
sounds like valves to me - are you checking clearance between the top of the rocker arm and the camshaft lobe? you <U>don't</U> check clearance between rocker arm and valve like on SOHC engine
Modified by jlicrx at 9:13 AM 3/13/2006
Old Mar 13, 2006 | 07:04 AM
Default Re: (jlicrx)
yeah im checking the clearance right
i replaced the head. and as soon as i put the new head on it made the same sound.
i checked anddouble checked and tripple checked the clearance, and all that jazz,
and still the sound remains. ive checked and double checked and 9847593476 checked the timing,
ive checked 98693286 time for just about everything, and nothing seems to be wrong,
but.. it keeps making this god forsaken sound and my car ran at first with this sound, and now it doesnt.
its REALLY pissing me off
Modified by i hate my ZC at 4:50 PM 3/13/2006
