91 std HATCH seat brackets for recaros... ug.. where do you guys get yours
Guest
Posts: n/a
I've looked for the cheap ones on ebay, and they only have 4 door.. i don't really wanna do the home depot plate steel way, thats a bit halfassed for something holding my life togther..
anyone ?
anyone ?
I just built a set for my Recaros in my 90 Si hatch. They were a bit of a pain, but not too bad. I'm a SS welder that works at a shop with mills and lathes so that made it easier. But here's how I did it. I used 2 pieces of metal, with countersunk holes to keep the mounting bolts flush. Then I mounted the one rail flush while the other needs to sit 1 5/8 higher. So I used some round bar drilled and tapped and welded them in the right spots. Without shop access, this wouldn't be possible, but and decent fab shop should be able to hook you up.
trunkluv
Nov 14, 2012 03:12 PM
1fast_Shoebox
Oct 11, 2007 06:28 PM
91' Z-6 Canadian hatch
Apr 30, 2004 08:03 AM
cbotha
Apr 20, 2004 09:21 AM
