DID I REALLY SCREW UP?
Old Mar 4, 2006 | 02:06 AM
nello a.'s Avatar
Default DID I REALLY SCREW UP?
just found out my torque wrench(one of three, but the one i trusted) is off. it reads 22ft/lbs when it really is 29ft/lbs. it reads 20 ft/lbs when it is really 22ft/lbs. i have used this to do suspension stuff. most recently the asr with itr sway i finished last night. no engine or brake stuff.
question: is 2-7 ft/lbs. going to make a big difference on suspension. am i paranoid. is **** going to break.
Old Mar 4, 2006 | 02:11 AM
john666's Avatar
Default Re: DID I REALLY SCREW UP? (nello a.)
i just use a gun or torque it on.
Old Mar 4, 2006 | 02:20 AM
nello a.'s Avatar
? or ?
Old Mar 4, 2006 | 02:31 AM
wrx'n you's Avatar
Default Re: (nello a.)
just get ur wrench recalibrated
Old Mar 4, 2006 | 02:36 AM
nello a.'s Avatar
screw the wrench. what about the car?
Old Mar 4, 2006 | 02:38 AM
wrx'n you's Avatar
nah it should be good
Old Mar 4, 2006 | 12:19 PM
nello a.'s Avatar
anyone else. how bout some of the engineer geeks?
Old Mar 4, 2006 | 12:22 PM
Padawan's Avatar
Darth ModerVader
For suspension work, the level of inaccuracy you're describing should not pose a problem.
Old Mar 4, 2006 | 12:30 PM
Civicse's Avatar
9 ftlbs doesn't mean **** for suspension. can't really be to tight, just as long as its not to loose. most ppl don't even use torque wrenchs for suspension anyway, your fine
Old Mar 4, 2006 | 12:55 PM
DSRxNATE DNRperformance's Avatar
Default Re: (Civicse)
it wont create a problem bro. its fine.
Old Mar 4, 2006 | 10:42 PM
nello a.'s Avatar
thank you. i can relax now. my friends think i am too picky about everything. i just want it done right. it bothers me if i do something incorrectly if i feel i know how to do it correctly. thanks again everyone.
mflannery1980
Aug 20, 2011 07:53 PM
