rear suspension conversion help please
Old Mar 3, 2006 | 09:01 PM
littletruck's Avatar
Default rear suspension conversion help please
well im putting the intera disk on the back of my rex and want to know what all i need for the swap i have the ebrake cable and the control arms what more do i need.
Old Mar 4, 2006 | 02:59 AM
JohnnieChimpo's Avatar
Default Re: rear suspension conversion help please (littletruck)
91 CRX Si rear brake lines
Old Mar 4, 2006 | 11:51 AM
civicandy's Avatar
you need: parking brake cable, trailing arms, brake lines. you can use the intergra reat upper/lower control arms to get a wider track, but be carful of tire rub if u use wide tires. i did the swap on my hatch. the entire rear is integra, including the sway bar
Old Mar 4, 2006 | 11:56 AM
mahatma's Avatar
Default Re: rear suspension conversion help please (civicandy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicandy &raquo;</TD></TR><TR><TD CLASS="quote">you need: parking brake cable, trailing arms, brake lines. you can use the intergra reat upper/lower control arms to get a wider track, but be carful of tire rub if u use wide tires. i did the swap on my hatch. the entire rear is integra, including the sway bar</TD></TR></TABLE>
What kind of difference did you notice with the teg rear sway??
Josh22999
Mar 28, 2007 10:30 AM
Captain JDM
Suspension & Brakes
Mar 20, 2007 12:48 PM
mnichols
Aug 22, 2006 06:59 PM
sekone
11
Jul 26, 2002 11:18 AM
handiman15
26
Apr 13, 2002 01:11 AM
