what the possibility of bent valves on a 92 integra ls with broken timing belt?
Old Mar 3, 2006 | 08:51 PM
tvrsir's Avatar
Default what the possibility of bent valves on a 92 integra ls with broken timing belt?
a friend broke while driving 20-30mph i heard ls have some good clearance valve to piston and i might be lucky to just thorw on a new belt. do i have a good chance?
Old Mar 3, 2006 | 09:25 PM
Diego Dangers.'s Avatar
i'd say fromw hat i've seen chances are pretty good. it is an interference engine, depends when it broke. its hard to say.
Old Mar 3, 2006 | 09:51 PM
four1one
Guest
Posts: n/a
Default Re: (Diego Dangers.)
the speed dont matter much what rpm was he at... the higher the rpm the more likely he is to bend a valve
Old Mar 3, 2006 | 09:55 PM
Sleeping_H22_DC2's Avatar
Default Re: (four1one)
chances are you bent some valves with these crap interface motors
timing belt usually break under higher loads = higher rpm = SOL
unless your really lucky for it to give under 2500 rpm or idleing
Old Mar 3, 2006 | 10:01 PM
SiR Mikey's Avatar
Like said above, it depends on the rpm you were at. The lower the better
Old Mar 4, 2006 | 03:44 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: what the possibility of bent valves on a 92 integra ls with broken timing belt? (tvrsir)
If the B18A is an interference engine, why does the RPM matter at all? The valves will still hit the pistons at 700RPM or 7000RPM. With a VTEC engine that is different because the non-VTEC mode should not interfere, which leads to the RPM dependence.
Mixmasta
12
Jan 17, 2020 06:55 PM
ajth87
Jul 13, 2006 02:18 PM
ericlee303
Apr 4, 2004 06:46 PM
SRC91Nteg
Nov 24, 2003 07:37 PM
Waachback
Oct 1, 2003 11:14 PM
