HOW TO FORD THROTTLE BODY ON A SKUNK 2 INTAKE MANIFOLD
Well this is going to be a quick lesson on how to do this conversion, a while back i got my tb from some guy and then I asked him how to install it and well guess what he was an *** and did not want to tell me how to do it, then i saw a guy with this tb and the same shitt they all try to ignore it when i would ask him how to do this conversion, so as u can see theres alot of racers out there that there friggin haters and dont want to help each other and just hate on others people ridez and talk crap when u ask for help, well my hate for that type of haters is what makes me want to help other people that run into shitt, well enough of that crap anyways here is how to
Well this is how you start, regardless if its a aftermarket mustang tb or a factory ford tb, well assuming you guys have the tb all ready or not the things you need to buy is,
edelbrock or stock ford throttle body
edelbrock adapter plate #number, 38112 for a 70mm inner 75mm outer throttle body
This adapter plate kit runs for about 40-45 bucks and i think is well worth it, it comes with all hardware and 2 gaskets.
Your next step you might want to take while your at it is to port match the throttle body size to the intake manifold once that is done and your ready to install it get a blade and cut the gasket thats between the throttle body and the intake manifold because one will come with the stock 65mm etc size, and the other will come with the 70 or 75mm gasket depending on your application, then after thats done just bolt the adapter with the gasket provided to the intake manifold and then bolt the throttle body with the other gasket provided to the bracket which will already be bolted to the intake manifold, after thats done the tps wiring will be next now pay attention to this because this is where i ran into problems because the fords tps colors are diffrent to the honda, so thats why i provided this little ghetto format, well regardless of how you take the conectors off, eighther if its dipinning the connectors or cutting them, (i recomend dipinning them, it looks cleaner) but anyways, you get electrical connectors and then match this colors,
WELL AS YOU CAN SEE HERE YOU MATCH THE, HONDAS YELLOW WIRE WICH IS THE 5 VOLT VOLTAGE WITH THE FORDS ORANGE WIRE
THEN U MATCH THE HONDAS RED WIRE WICH IS THE TPS SIGNAL WITH THE FORDS GREEN WIRE
AND THEN U MATCH THE HONDAS GREEN WIRE WHICH IS THE GROUND TO THE FORDS BLACK WIRE
Well after this is done you can installed your intake manifold back on your cylender head and you should be good to go,
Well here are some pics of the skunk 2 intake manifold with the edelbrock 70mm inner 75mm outer throttle body with the Edelbrock adapter plate remember the part # is 38112 for the 70mm, the 75 inner is a diffrent part number and i dont know it but I think is like 38111 not shure thou, well anyways thats preatty much it and i hope this and I have been helpfull to somebody, I KNOW THIS WOULD OF HELP ME ALOT i spend hours on the internet trying to find something like this and never found it, but anyways here are the pics and i hope ill be usefull to somebody, thanks for dropping by and checking this out.
Modified by azimoeg at 8:55 PM 3/3/2006
EXCELENT WRITE UP
ITS GOOD TO SESOMEONE HELPING OTHERS OUT
IM GOING TO DO THIS TO MY DRAG INTEGRA NOW,IVE BEEN LOOKING FOR A BIGGER TB,
THANKS.....
THANKS.....
thanks for the props and im not shure what year exacly it is because the guy i got it from never told me anything about it but im shure it doesent matter what year it is, but anyways like i said before this setup is for sale if you know anybody that would like this tell them to hit me up, this will help me in buying my new parts for my h22 swap thanks
Here is some information I have put togather for that throttle body
2000 Si
Honda Wire Edelbrock TPS
Red/black Input Orange
Yellow/blue Output Green
Green/black Ground Black
1992 - 1995 Civic
Yellow / White Input Orange
Red / Blue Output Green
Green / White Ground Black
1994-1995 Integra LS and GSR
Yellow / Blue Input Orange
Red / Black Output Green
Green / Blue Ground Black
2000 Si
1992 - 1995 Civic
