Intrusment cluster bulb #'s?
Some of my lights have gone out on my guages and around the A/C etc...Anybody know what all bulb numbers they are?Maybe a chart of each.
Anything the watch out for when replacing the intrusment cluster ones?
the bulbs for the gauges are 194, and the ones in the climate control im not exactly sure, i just went to the dealership and asked for climate control bulbs, and they knew what i was talkin about
Actually the instrument cluster is a combination of 194s and 74s. The climate controls (fan speed, mode selection, etc) are 74s. This is for a 2nd gen teg. If you do indeed have a 2nd gen teg, then check out this thread:
http://www.g2ic.com/forums/sho...hting
Make sure to look for the posts made by me (same name on G2IC as here on HT).
Cliff notes from a post by me in that thread:
<<If by confirmed you mean what I can remember off the top of my head (but I know for a fact it worked for me), youll need the following:
2 194 "wedge" bulbs for the cluster (a third one will be needed if you plan on replacing the low gas light indicator, but only 2 are actually needed for lighting the cluster up)
3 74 bulbs for the cluster itself
2 74 bulbs for the light bar above the cluster (i didnt put them in for my conversion, though. I found it took away too much from the look I was going for)
2 74 bulbs for lighting behind the selector for where you want the air to blow
1 74 bulb for temp control
1 74 bulb for the ashtray
1 74 bulb for the cig light illumination
The light above the CD player/headunit, I had to buy an LED, solder (in series) the correct resistance (used two resistors, different ohms), then soldered that inline with the supplied positive/negative wires that were already there).
That should be all the correct lighting, listed above. This does not include any of the lighting for the hazard/defog/etc switches. Any questions, let me know.>>
More info in this thread too:
http://www.g2ic.com/forums/sho...pp=20
Hope this helps.
-- Kevin
Hope this helps.
-- Kevin
jadeyedragon_01
16
Mar 10, 2014 07:05 PM
jdm_ek_noob
Jun 4, 2011 04:44 PM
vegaspartyy
Mar 15, 2008 11:32 AM
jlamaster
Jul 28, 2003 06:05 PM
