Differenced between D15B2 and D15BZ^(JDM) engines!
Old Mar 3, 2006 | 06:56 PM
FarFetched's Avatar
Default Differenced between D15B2 and D15BZ6(JDM) engines!
Hi everyone!
I ma swapping engines. I got a D15BZ6 V-TECH (92-93). Eng block stampoed D15B.
My questions are, will distributor from D15B2 (old engine) work on new motor w/o connectin? V-TECH plug. Which timing maks should I use when changing timing belt (I got access to ALLDATA). I am getting different settings for different engines, but none of them for D15BZ6!
Any experts in this stuff?
Thanks in advance!
Petr.
Old Mar 3, 2006 | 09:06 PM
jlicrx's Avatar
Default Re: Differenced between D15B2 and D15BZ6(JDM) engines! (FarFetched)
it is not a D15BZ6 that you are looking for - the JDM engine is a D15B which is similar (not the same) as US D16Z6 - no, your D15B2 distributor will not work - it doesn't have the sensor required to run the Multi Point Fuel Injection
Old Mar 3, 2006 | 10:14 PM
FarFetched's Avatar
Default Re: Differenced between D15B2 and D15BZ6(JDM) engines! (jlicrx)
Thanks!
My 91 civic wagon has PMG FI with TB FI.
I am gonna return this engine because sales rep doesn't know JACK-A$$!
Thanks again!
Old Mar 4, 2006 | 05:45 PM
jdmsteveo05's Avatar
just an idea but atleast know the engine you want before talking to sales reps. They dont give a rats *** about you. they wanna feed the family and if youre gullible(sp) enough then go get the "d15bz6"
Old Mar 4, 2006 | 06:42 PM
si0385.'s Avatar
Default Re: Differenced between D15B2 and D15BZ6(JDM) engines! (jdmsteveo05)
i have the jdm d15b i like it
they are not hard to put in you car there are endless writeups on thsi site to put this motor in you car and get it running
just search and any info on the d16z6 will help you out to they are basicaly the same motor
therest
Oct 19, 2015 09:30 PM
stellium
Feb 25, 2010 03:27 AM
RaCk
21
Jun 16, 2006 02:42 PM
Feriofan
Jul 29, 2004 11:27 AM
