Are my bearing journals okay?
Old Mar 3, 2006 | 06:19 PM
ozzyman's Avatar
Default Are my bearing journals okay?
**UPDATED!!
Judging by one of the main bearings, do you think my main journals are okay? I forgot to take a picture of the journal but this is one closest to the flywheel. Only this journal is questionable to me... the rest look perfect. Also it doesnt look like I spun the bearing... its hard to explain but it just looks like some of the meterial from the bearing stuck onto the journal or something. I'll try to get pics of the journal.
**Finally took pics of the main journals and such. Here is what the journal looks like for bearing above. I scraped off most of the darker metal stuff with my finger nail, brake cleaner and a rag, but some of it is pretty stuck on there. Also is the copper color normal?
Does it look okay? Like it wouldnt effect the oil clearance? Also here are pics of the rest of the journals along with the main caps.
Modified by ozzyman at 1:58 PM 3/17/2006
Old Mar 3, 2006 | 08:56 PM
ozzyman's Avatar
Default Re: Are my bearing journals okay? (ozzyman)
Anyone?
Old Mar 3, 2006 | 09:20 PM
werksberg's Avatar
Any performance engine should have the mains aligned hone to be perfect straight and 90 degree to the cylinders too. Regural mass production is good for a street car but.....
Old Mar 3, 2006 | 10:16 PM
EnzoSpeed's Avatar
Default Re: Are my bearing journals okay? (werksberg)
I've never seen that. Kind of weird. Does the tang on each bearing look perfect/un-crushed?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by werksberg &raquo;</TD></TR><TR><TD CLASS="quote">Any performance engine should have the mains aligned hone to be perfect straight and 90 degree to the cylinders too. Regural mass production is good for a street car but.....</TD></TR></TABLE>
Don't drink the bong water.
Old Mar 4, 2006 | 04:02 PM
ozzyman's Avatar
Default Re: Are my bearing journals okay? (EnzoSpeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnzoSpeed &raquo;</TD></TR><TR><TD CLASS="quote">I've never seen that. Kind of weird. Does the tang on each bearing look perfect/un-crushed?
LOL.
The tangs look perfect. Actually now that I look at it.. alot of the bearings look kinda copperish on the back side. Is that normal? I really need to take pictures of the mains.
Old Mar 4, 2006 | 04:56 PM
BigMoose's Avatar
Lets see the wear surfaces and the back shells... all of them. Just line them up tops and bottoms.
Old Mar 4, 2006 | 06:45 PM
non-VTEC's Avatar
we need to see the bearing surface where the crank journal actually sits in.....the backside looks shitty but probably wont cause a problem.
Old Mar 4, 2006 | 07:56 PM
ozzyman's Avatar
Default Re: Are my bearing journals okay? (non-VTEC)
I'll try to get new pics up tomorrow.
Old Mar 17, 2006 | 12:59 PM
ozzyman's Avatar
NEW PICS.
Old Mar 17, 2006 | 06:52 PM
d16dcoe45's Avatar
That bearing is ready to spin. Something went wrong. Is this a factory motor or did you build it?
Old Mar 17, 2006 | 09:16 PM
alpine_hikr's Avatar
Default Re: Are my bearing journals okay? (d16dcoe45)
you shouldnt be seeing any copper material on your bearings...
Old Mar 18, 2006 | 02:58 PM
ozzyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16dcoe45 &raquo;</TD></TR><TR><TD CLASS="quote">That bearing is ready to spin. Something went wrong. Is this a factory motor or did you build it?</TD></TR></TABLE>
It is indeed the factory motor and I never touched anything inside, besides doing a valve adjustment a couple times.
Should I get an align bore? I plan on doing a complete rebuild so do I have to worry about my new bearings spinning?
Old Mar 18, 2006 | 06:15 PM
ozzyman's Avatar
Anyone else have any input?
Old Mar 18, 2006 | 07:02 PM
mmuller's Avatar
Mad Scientist
the bores look ok.
for more input we need pics of the bearings..
weekendboost
Engine Machining & Assembly
Apr 25, 2017 08:53 PM
Fishy_hondaman
Sep 18, 2016 10:05 PM
GaRn
Dec 30, 2005 10:57 PM
Sonny
Dec 27, 2002 10:32 PM
