B18c5?
Old Mar 3, 2006 | 06:19 PM
wood's Avatar
Default B18c5?
Is this the GSR motor and if so what is best head to use on it? want to go NA and get good but not extreme horsepower. Is it vtec? give me clues for a search. what should I enter to search this engine? Not had much luck with what I have tried. Thanks
Old Mar 3, 2006 | 06:22 PM
Sikocivic's Avatar
Default Re: B18c5? (wood)
B18c5 is the Integra Type R motor.
Old Mar 3, 2006 | 06:59 PM
Ak_ef9's Avatar
Default Re: B18c5? (Sikocivic)
That is a type r motor and it comes stock with around 197 hp. If its going in a crx/ or hatch I would focus on traction as with my b16 I have trouble hooking up in first and part of 2nd. Other then that just get the basic like intake header exhaust and all the other bolt ons and you can easilly achive good numbers with that motor
Old Mar 3, 2006 | 07:16 PM
SiR99's Avatar
the b18c5 is the type R motor and it puts down around 165 whp. With i/h/e it will put down 175-185 whp. The tranny comes with lsd so traction should be that much of an issue. I saw a 92-95 hatch with this motor + i/h/e tuned hit 12's. The only problem is that it is a really expensive motor.
Old Mar 3, 2006 | 07:30 PM
Steri's Avatar
What did you search for? Because I just did a search for b18c5 and I got 56 results a majority of which explain that this is a type R motor! What do you post about with 180 something posts?
I don't mean to be a jack *** I'm just baffled that you claim to have searched, and didn't figure out that the c5 is a type R.
Old Mar 3, 2006 | 07:53 PM
wood's Avatar
Default Re: B18c5? (89EF_Sleeper Si)
I asked for clues to search this, if you had read my post you would know that. Thanks because you gave me the answer. Just thoght I would ask because many times I get no results because I am not sure what to enter. Why do you mention the # of posts? I respond to issues I know about and stay out of others. I am still learning and use this site to help me do this. Thanks for the flame.
Dan
Old Mar 3, 2006 | 08:49 PM
Steri's Avatar
You're right I miss read your post! I thought you said that you already searched for b18c5. I didn't mean to flame! When you search here it's best to be as general as possible because then you can slowly look for the information you are looking for, and at the same time learn about other issues related to the general topic you are looking for!
I really didn't mean to be a jack ***!
Sorry!
Old Mar 3, 2006 | 08:50 PM
EL Vap133's Avatar
Come on man!
MadCityVtec
Feb 17, 2009 11:08 PM
jimep386
Dec 16, 2006 09:56 PM
GserpleaSR
Nov 9, 2006 07:06 PM
Tom123456
May 12, 2006 07:27 AM
HondaRacer32
Jan 4, 2004 03:35 PM
