drag slicks
Old Mar 30, 2002 | 11:33 AM
NW94RS
Guest
Posts: n/a
Default drag slicks
i know how this is a road race biased board but there is times when i do go out and run my car down the 1/4. just wondeing if anyone knows of a 5 lug drag rim that slicks can be put on
Old Mar 30, 2002 | 12:07 PM
civicjunkie's Avatar
New User
Default Re: drag slicks (dc-2R)
i think the crv steel wheels should work
Old Mar 30, 2002 | 12:09 PM
Stumpy's Avatar
Default Re: drag slicks (civicjunkie)
Sorry this doesn't really answer your question.
Do drag slicks help times by giving more traction on the launch, or do they help time because of the reduced rolling resistance over normal street tires?
Old Mar 30, 2002 | 12:25 PM
ARunto's Avatar
Default Re: drag slicks (Stumpy)
They help off the line traction. Rule of thumb is that if you knock .1 sec of 60 foot you'll knock .2sec of your 1/4 mile ET.
Try using some 22X8X15 Mickey Thompsons
-Alan
Old Mar 30, 2002 | 12:34 PM
py1188's Avatar
Probably a little bit of both. Just overall sticky tires equaling better traction, and if you're using a 555R, the lower profile will add to your FD ratio
dc2r...most people use stock ITR rims because there really aren't any drag wheels out there, unless you wanna spend the money on some koseis or some other aftermarket wheel. I actually have 2 already mounted on drag radials for sale if you're interetsed. CHeck the link below
Old Mar 30, 2002 | 03:12 PM
PM-Performance's Avatar
Default Re: drag slicks (py1188)
any bullshit light weight 5 lugs will work . i got my mickey thomsons on konig tequillas for now .
this year i think im gonna swap em over to another 2 slipstreams . they are just a **** hair lighter.
Old Mar 30, 2002 | 03:26 PM
nfn15037's Avatar
Default Re: drag slicks (itr206)
I have some 300z 15 inch wheels that fit an ITR. They are nice and wide too. $75 plus shipping.
Old Mar 30, 2002 | 03:37 PM
Pinhead's Avatar
New User
Default Re: drag slicks (nfn15037)
that's a GOOD deal nfn15037 go for those dude
Old Mar 30, 2002 | 05:55 PM
Dropspeed's Avatar
Default Re: drag slicks (Pinhead)
It sounds like you want slicks, but if your looking for a drag tire for the occassional outing to the strip I have been very happy with the new BFG Drag T/A I run them all of the time, except when the car is on a road course. I have run 1.9 60ft on a 205/40/17 at 15 psi. Air them up and drive the car home. NOTE: my car is not a daily driver so I have never driven on them in a down pour or in snow.
Mattj
Old Mar 30, 2002 | 10:11 PM
GokuSSJ4's Avatar
Default Re: drag slicks (Dropspeed)
M/T slicks
for wheels if you want to spend the $$$ bogards on 14 , you need longer studs do'h .
Old Mar 31, 2002 | 02:54 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
i have a set of 15x7 kosei's with m/t 22x8-15 slicks for sale. 9 passes total.
https://honda-tech.com/zerothread?id=154605
email me if you are interested. thanks.
Old Apr 1, 2002 | 10:41 PM
GokuSSJ4's Avatar
Default Re: drag slicks (rodney)
how much? email me if you havent sold them !
Old Apr 2, 2002 | 02:42 AM
Rodney's Avatar
Default Re: drag slicks (Spoon1)
sorry. i am currently waiting for a check. if the seller flakes, which i doubt, i will email you. thanks.
Old Apr 2, 2002 | 05:30 AM
the bogarts are nice but expensive.
i got my wheels for lie 160 for the set brand new. and 14's wont fit the r. got to convert the front susp to put em on . the brakes are too big in the front.
Old Apr 2, 2002 | 09:30 AM
GokuSSJ4's Avatar
you could fit 14 with a spacer built on the front? at least that i was told from monocoque wheels which they been around for lik 65 years and there the same design as bogards and also was told that the guy from bogards came out.
also does any one have the site for bogards wheels
and the samething is done on gsr to run 13's
Old Apr 2, 2002 | 09:35 AM
MPH's Avatar
MPH
New User
"also does any one have the site for bogards wheels"
http://www.bogartwheels.com/
Old Apr 2, 2002 | 10:36 AM
Default Re: drag slicks (MPH)
i would love to see 14's on an r. . . on stock front susp.
my 15's barely fit . the wheel is almsot on the damn brakes.
post pics when you get em , cuz i dont see it working easily.
Old Apr 2, 2002 | 11:39 AM
MPH's Avatar
MPH
New User
I would like to see this also. If this is possible, I'm doing it.
Old Apr 2, 2002 | 12:24 PM
sgT's Avatar
sgT
14s WILL NOT FIT.
IF anyone is still interested I have a set of MT 22x8x15 slicks mounted on
legend wheels for sale.
Old Apr 2, 2002 | 12:34 PM
TypeR0207's Avatar
Default Re: drag slicks (sgT)
I just ran my 22/8/15's on one pair of the stock rims ...... since I had aftermarkets for daily driven.
The stock wheels are pretty decent as far as weight goes, and they worked fine with slicks. If you don't have aftermarket wheels for daily driving, just spend a couple bucks on some cheapy steelies or a cheap set of alloy wheels. It's not like you are going to blast around corners on them ....
Old Apr 2, 2002 | 12:50 PM
GokuSSJ4's Avatar
Default Re: drag slicks (TypeR0207)
thanks for the link!
well i call bogards and they do make it in 14 with a spacer for clearence
but im going to make sure by calling kg engineering in huntinton beac to make sure and , to what is available.
if not well i think some rotas sliptream would be good in15's there light and cheap and slap on some M/T slick are ready to go!
Old Apr 3, 2002 | 09:35 AM
bananacruzier's Avatar
i just got a set of nitto 555R and plan on tring these out at the track this weekend. to all the people who had experiment with these what do you guys think about it? about how much psi should i put in them for best result? i know every car will response different but just what to get an idea of what psi i should use and try.
just want to know whats to low and whats to high, and about how high were you able to rev to when using these wheels?
96civic cr-v
Nov 17, 2007 09:46 AM
litovi3tboi503
Apr 4, 2007 02:13 PM
93H22ACX
Jul 14, 2004 02:38 AM
Foowee
Apr 15, 2004 08:25 PM
