How can I get some low end
Old Mar 30, 2002 | 11:20 AM
billabongrob's Avatar
Default How can I get some low end
Hey I have a 90 integra 4 dr automatic not too much fun and I was wonderringwhat mods I could do for low end because now I have an intake, gutted cat and a straight through exhaust and I can spin my tires in the rain...I was wonderring if somethings wrong or if I dont have neough backpressure...once I hit higher RPMS i can feel it start moving but thats all and I've lost races due to the cars hesitation....help me out btw whats the slickest solution that can be run through the windshield washer system?
Old Mar 30, 2002 | 11:52 AM
Regular Series's Avatar
Default Re: How can I get some low end (billabongrob)
I dunno...the auto tranny is a real killer for high-revving cars like Tegs. The gears are way too tall and the shifts are too slow.
Backpressure is not your friend, but if your exhaust is too big you will lose flow velocity, that's why a too-big exhaust is no good. You should need no more than 2.5" diameter exhaust on a largely stock Teg.
The only thing I can think of is a supercharger. Supposedly the Jackson Racing unit fattens your torque band considerably.
edit: minor re-phrasing.
[Modified by risingson77, 3:53 PM 3/30/2002]
Old Mar 30, 2002 | 12:30 PM
Leimokei's Avatar
New User
Default Re: How can I get some low end (risingson77)
problem = tranny
tires = traction control...
swap to 5spd or get sticker tires...
2ndly..if you want low end power...= more torque...
1. you can wrap your intake....
2. port your intake manifold
3. get bigger throttle body
4. crower intake cam..
adjust your timing on your intake and leave your exhaust @ 0 degrees.
Old Mar 30, 2002 | 04:17 PM
B18 B e a s T's Avatar
Default Re: How can I get some low end (Leimokei)
Get 2.5 inch intake pipe, 4-2-1 exhaust manifold.
Old Mar 30, 2002 | 04:31 PM
1fastGSR's Avatar
New User
I bet you lost lots of low end with that gutted cat
Old Mar 30, 2002 | 04:52 PM
Ri5e's Avatar
Default Re: How can I get some low end (1fastGSR)
Yeah, you will lose a lot of low end with the gutted cat. Gain slight up top power, but your low end will hurt you with the gutted cat....
Old Mar 30, 2002 | 05:19 PM
Default Re: How can I get some low end (BG Boost)
Actually, a gutted cat can cost you power. Think about it: rather than a nice, smooth tube of constant diameter you have this lumpy widening and narrowing one. Generally aftermarket intake and exhaust tubing (of any quality) will be smooth and the diameter is constant. If the tube widens or narrows, it does so gradually. The abrupt widening and narrowing of a gutted cat will often decrease overall flow velocity. You might get slightly better throttle response and more noise. They give the impression of power, but the butt dyno is deceptive at best.
Not the best explanation, I know. Hope it helps anyway.
Old Mar 30, 2002 | 08:49 PM
so should I get a stock cat or a test pipe?
Old Mar 30, 2002 | 09:27 PM
owen_the_soyboy's Avatar
B20 !!!!
get a CRV bottom end and bolt that thing right up in there, you'll be all set with more lowend.
easy to do and only about $800.. plus you can sell your stock bottom end to someone doing an LS turbo or LS vtec setup.
Old Mar 30, 2002 | 10:18 PM
SIK IN DA HED's Avatar
New User
Default Re: How can I get some low end (owen_the_soyboy)
dude... you dont need to do ****. you have an auto. the only way to go is forced induction.
Old Mar 31, 2002 | 08:25 AM
Default Re: How can I get some low end (dlplayboy)
my car is 12 years old and has 191,727 miles on it I dont think I can go forced induction of any kind...would dropping a 5 speed be a better plan?
Old Mar 31, 2002 | 09:12 AM
punk749's Avatar
if i were you...i would get a new motor...save up and just get a b16a...or spend a little more and get a GS-R...since you have an auto with so much milage i think you would save money in repairs...and your mods will be much more significant with a new motor that is a manual...hope it helps...and i am selling some chikara 4-2-1 tourques step header which will give you some lower end tourque and lower end power...so if you are interested e-mail me at deparsons@cinci.rr.com...see ya...
later,
Dan
Old Mar 31, 2002 | 09:34 AM
Hm, I don't think I'd continue to mod my engine with that many miles on it. It's nearing the end of its life cycle, even unmodified. Save your cash for a B18 swap.
Old Mar 31, 2002 | 10:10 AM
slowerthanu's Avatar
New User
Buy a Camaro.
Old Mar 31, 2002 | 10:55 AM
Default Re: How can I get some low end (slowerthanu)
Buy a Camaro.
best suggestion yet.
Old Mar 31, 2002 | 11:44 AM
Default Re: How can I get some low end (punk749)
hows about some CRV cams? I'm really looking to rebuild this engine cuz its a good engine just old how hard are cams to install?
Old Mar 31, 2002 | 11:51 AM
lilblacksol's Avatar
the main problem you have is the automatic tranny,the only fast automatic hondas i know of is 92-95 prelude si's,and v6 accords.........everything else i saw was pretty slow.
Old Mar 31, 2002 | 12:28 PM
frostwhite_92's Avatar
Get a B20 long block.
Swap your intake manifold on it.
Find an LS cable tranny/clutch.
Put everything together.
Put it in your car.
End of story.
Old Apr 1, 2002 | 07:10 AM
bps2799's Avatar
Really, the best thing you can do is save $$$ for a newer car. Think about it. Everything on your car is old and going to wear out (= $$$ to fix). Putting a new engine in an old, not especially valuble car isn't really worth it, esp. if this is your daily driver, not a track *****.
You've got a sucky automatic, but putting in a 5-speed isn't a panacea. I drove a 5-speed G2 teg for 8 years. There are automatic family sedans, probably most family sedans, that'll suck your doors off even w/ a stick.
Save the money for a newer integra and work from there on mods.
Old Apr 1, 2002 | 09:38 AM
New User
Default Re: How can I get some low end (bps2799)
yeah, youre better off gettin a new motor. just take it easy on the one you got. dont spend anymore money on it. the basic boltons you got are coo. i would recommend a 5speed conversion.
Old Apr 1, 2002 | 09:41 AM
New User
Default Re: How can I get some low end (LSnoVTEC)
Buy a new B18B and boost it. You can even keep the auto tranny, in fact the auto is probably better for turbo anyways. Just upgrade your tranny cooler and torque comverter.
who said auto was better for a turbo? i dont think so buddy. its only better if you cant drive for ****.
5spdcoupe
Aug 4, 2007 03:08 PM
es_squared
Apr 6, 2004 02:43 AM
slp mode
Dec 19, 2003 04:12 AM
SoCal ITR
Oct 15, 2001 05:17 AM
