how do you know when your headgasket is blown
here are the only ways i know how to tell. if there is oil in your coolant, if you see seepage around your head. if your blowing white smoke. Hope to have helped ya man. hope the best of luck
bump for more answers and thanks for the info its a negative on all of those i just suddenly over heated radiator pushes out coolant when engine is revved
I used to blow headgaskets all the time on my d series. It would always start pushing coolang out of the overflow bottle, overheating, but never any oil in the coolant. Thats only if the leak is real bad. I guess mine never were.
i think it is because i put water in the rad and it evaporated why i overheadted cause i just took it for a test run and it didnt overheat again radiater was still full of water gonna put coolant in it tomorrow still watching it though
you have air pockets in your coolant or your rad is plugged and needs flushing or replaced.. thats my .02
most of the symptoms for a blown HG are lose of power, overheating, over pressureized cooling system (my rad exploded in my face because of this on a previous car) oil in coolant or coolant in oil and milky looking oil (white, grey, etc)
im not sure if theres anymore but those are the ones i know
what i did when i had air pockets
waited for the car to cool down a bit after a warm up drive, took the cap off, started the car and let it idle, and put in coolant as the thermostat let the motor suck in more from the rad, eliminateing the air pockets in the process, havent had a problem since
there may be a better way, but thats what worked for me
hybridb18
Aug 6, 2003 09:00 PM
