RECARO infant seats are here at last! Many colors to choose from are in stock! SafeDrives.com
Old Mar 3, 2006 | 11:16 AM
Safe Drives's Avatar
H-T Basic Sponsor
Default RECARO infant seats are here at last! Many colors to choose from are in stock! SafeDrives.com
Finally the Recaro infant seats are here. many of you have been waiting and they are now in stock and ready to ship! Hurry because these seats are selling fast!
ALL RECARO CHILD SEATS SHIP FOR FREE TO THE LOWER 48!!!
Check out the Recaro Young Sport Child Seat
This innovative child seat offers the latest safety protection like energy-absorbing EPS foam, deep side wings and an excellent for children weighing 18- 80 pounds.
Due to its outstanding versatility, it provides the perfect platform on which to watch your child grow. With its height-adjustability it offers optimum safety for toddlers and young children. And as soon as your child outgrows the 5-point harness and seat cushion, you can remove them, converting the Young Sport into a booster seat.
Belt positioning Booster for Children weighing 18 - 80 lbs and height of 59 inches or less.
RECARO SIP
Improved safety thanks to this innovative Side Impact Protection system. The extra large side protection shell provides additional support when cornering.
SIMPLICITY AT HAND
Multi-level adjustable headrest.
ERGONOMIC SHAPE
For healthy growth
SEATING COMFORT
Integrated armrests
EXCELLENT FIT
Removable fit for each age group.
CONVENIENCE AND SAFETY
Central belt adjuster for quick harness adjustment (5-pt. only)
EASY INSTALLATION
Simply secure the seat with its LATCH System* or with the car's existing 2-* or 3-point seat belt. *only when used with the integrated harness system
INCREASED SAFETY
Highly visible red marking show the belt routing locations and help you slide the seat belts into the right position.
CONVENIENT
Carry handle for easy transportation.
IMPACT SAFETY
Energy absorbing EPS foam is used in sensitive head and shoulder area.
TRAVEL COMFORT
Comfortable padding for long journeys. FOR CHILDREN WEIGHING 18 - 40 LBS Use the integrated 5-point harness system. FOR CHILDREN WEIGHING 30 -80 LBS Remove harness system and use as belt positioning booster.
INNOVATIVE BELT ROUTING SYSTEM
Specially designed hooks hold belts firmly in place.
HIGH QUALITY UPHOLSTERY
Innovative and easy-to-clean Microfibres® in stylish colors. All covers are removable and machine washable at home.
SLEEPING POSITION
A simple turn of the ****.
Suited for use in vehicles fitted with 2-point belt, 3-point safety belt and LATCH system with separate seat integrated 5-point harness for a child of Class I.
With integrated harness system for children weighing between 18 and 40 lbs. (8 and 18 kg), and whose height is 59 inches (150 cm) or less.
Without (removed harness system) as booster seat for children weighing between 30 and 80 lbs. (14 and 36 kg), and whose height is 59 inches (150 cm) or less.
Suitable only for forward-facing installation.
Engineered in Germany, manufactured in the USA.
YOu can buy it now right here http://www.safedrives.com/prod...at=45
Also available now is the Recaro Young Style Child Seat
As your child grows - so do his or her demands. The Recaro Young Style child seat not only looks good, it also offers excellent side-protection for your child due to its extra large head and side and fully adjustable headrest. In addition, it is equipped with a convenient carrying handle and can easily be transports between vehicles. The Young Style's comfortable padding, its adjustable backrest and integrated armrests add fun and pleasure to every journey.
RECARO SIP
Safety PLUS
Energy absorbing EPS foam in sensitive head and shoulder area.
TRAVEL COMFORT
ERGONOMIC SHAPE
For healthy growth.
EASY INSTALLATION
Simply secure the seat with the car's existing 3-point seat belt.
CONVENIENCE
Carrying handle for easy transportation. Safety Multi-level height adjustable headrest for optimum fit.
SEATING COMFORT
Integrated armrests
INCREASED SAFETY
Highly visible red markings show the belt routing locations and help you guide the seat belts into the right position.
This is a Class II to III seat for children weighing between 30 and 80 lbs. (14 and 36 kg), and whose height is 59 inches (150 cm) or less.
Get this great seat here http://www.safedrives.com/prod...at=45
You can still get the Recaro Start seat as well. We've sold tons and tons of these great seats.
The RECARO Start Child Seat offers children 30lbs- 80lbs, approximately 3.5 years - 12 years the safety and comfort of an adult seat.
It has already received several awards for its innovative general concept of providing children with a comfortable and safe travelling environment.
When designing the Start, RECARO paid special attention to an ergonomically correct sitting position and built in a variety of very practical features.
RECARO Start is currently the only child safety seat developed on the basis of a tubular aluminium construction, helps to absorb energy by deformation in the event of a crash. This RECARO invention bends on impact, absorbing energy in an accident.
The specially contoured seat cushion forms an anti-submarining ramp which helps prevent sliding forward under the safety belt in a crash.
A reinforced, anatomically designed, integrated headrest as neck protection - giving support and comfort when resting, and protection in case of a side-on collision.
Age-specific adjustable and lockable guides to help the belt moves smoothly, irrespective of your child's size.
> The RECARO Start is individually variable in height, shoulder width and seat length, for a proper seating posture
> The RECARO Start is the first child safety seat to be awarded the Healthy Back Campaign seal of approval by leading back specialists (AGR)
> Optional, ergonomically designed lumbar support for correct seating - support for the spine during the growing phase
> Excellent ventilation is the key to your child's well-being
> What is standard equipment in car seats should be an essential for your child too. In contrast to child safety seats of hard plastic material, the integrated comfort-mat helps to distribute seat pressure and offers a pleasant drive especially on long trips
> And when your child gets sleepy along the way, you can easily change the seat into its resting position*
> High positioning and an unimpeded view make the start especially popular with curious youngsters
*The resting position is suitable for the ECE categories I - II only, i. e. for children from approx. 9 months to 6 years and 30-80 lbs.
Standard features:
New: RECARO sound system: headrest integrated sound speakers for an individual audio program
New: Innovative cover materials
Integrated headreast for overall head protection
Adjustable backrest with head support
Adjustable shoulder support
Belt clamp / guide
Lumbar support individually paddable
Seat cushion length adjustment
Foldable for easy transportation
Resting position
Covers machine-washable up to 40° C (104° F)
Extremely hardwearing cover materials
24 months guarantee
Top tether for correct installation in the car
Tested & approved to US standard FMVSS 213 (Federal Motor Vehicle Safety Standard) and ECE-R 44/03 standards.
Incidentally, the RECARO start has already received several awards for its innovative general concept: for example, the International Design Prize awarded by Baden-Württemberg Germany.
This is a Class II to III seat for children weighing between 30 and 80 lbs. (14 and 36 kg), and whose height is 59 inches (150 cm) or less. Suitable only for forward-facing installation. Engineered in Germany, manufactured in the USA.
FREE Shipping is UPS GROUND to the continental USA only. Call us for the shipping cost for shipping to another country.
Send me a IM with any questions.
Old Mar 6, 2006 | 12:36 AM
FULL throTTLe's Avatar
i want a kid now
Old Mar 6, 2006 | 01:03 AM
kapoosh valve's Avatar
when prices aren't posted, thats never a good sign.
Old Mar 6, 2006 | 07:41 AM
H-T Basic Sponsor
Default Re: (kapoosh valve)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kapoosh valve &raquo;</TD></TR><TR><TD CLASS="quote">when prices aren't posted, thats never a good sign.</TD></TR></TABLE>
Yes, they are kinda pricey but NICE.
Old Mar 6, 2006 | 11:05 AM
H-T Basic Sponsor
Default Re: RECARO infant seats are here at last! Many colors to choose from are in stock! SafeDrives.com (S
Old Mar 7, 2006 | 02:10 PM
H-T Basic Sponsor
Old Mar 10, 2006 | 08:24 AM
H-T Basic Sponsor
Old Mar 14, 2006 | 08:08 AM
kniob's Avatar
holy carp. ... I don't plan on having kids... but I'll buy one in the future just to cart around my gf's sister's kids sometimes!
Old Mar 15, 2006 | 08:21 AM
H-T Basic Sponsor
Old Mar 21, 2006 | 01:23 PM
H-T Basic Sponsor
Old Mar 24, 2006 | 12:05 AM
super_mut's Avatar
Ehh dunno bout the kids but, definetely about the seat
Old Mar 31, 2006 | 08:51 AM
H-T Basic Sponsor
Old Mar 31, 2006 | 03:47 PM
tnewhallSi's Avatar
imagine the lucky kids getting to ride in these seats haha, way cool
Old Apr 3, 2006 | 10:42 AM
H-T Basic Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnewhallSi &raquo;</TD></TR><TR><TD CLASS="quote">imagine the lucky kids getting to ride in these seats haha, way cool </TD></TR></TABLE>
I know!
Old Apr 3, 2006 | 12:22 PM
TSX TEX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super_mut &raquo;</TD></TR><TR><TD CLASS="quote">Ehh dunno bout the kids but, definetely about the seat </TD></TR></TABLE>
LOL I heard that Tight baby seats
Old Apr 3, 2006 | 02:56 PM
JERKSiRcoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Safe Drives &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Old Apr 3, 2006 | 04:24 PM
Spence's Avatar
Bump for the best customer service i have recieve in a long time
Old Apr 3, 2006 | 11:52 PM
super_mut's Avatar
Default Re: (Spence)
For the youngin's! Sometimes I wish I was young again, life wouldn't be complicated
Old Apr 13, 2006 | 05:24 PM
Flite's Avatar
A friend linked me to this thread, since I'm not a normal Honda-tech reader I can't use the PM function (I dunno what that's all about). I would like to get a quote and most likely purchase a young sport child seat (first one pictured) in flash and shipped to Hawaii, zip code 96789.
Sorry I can't use the PM, you can reach me via Email at CGFlite@yahoo.com. Thanks in advance!
Chris
Old Apr 17, 2006 | 08:36 AM
H-T Basic Sponsor
Thanks for your order Chris!
Old Apr 24, 2006 | 10:15 AM
Spence's Avatar
Charles doing his thing this weekend guys!!!
Keep supporting him
Old Apr 24, 2006 | 03:16 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Dude, Im about to steal someone elses kid to get one of those... aren't they around 300$?
Old Apr 26, 2006 | 10:36 AM
H-T Basic Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">Dude, Im about to steal someone elses kid to get one of those... aren't they around 300$?</TD></TR></TABLE>
I think kids costs a bit more than that.
Old Apr 26, 2006 | 01:00 PM
Spence's Avatar
Bump for the safety man!
Old Apr 26, 2006 | 01:20 PM
E.46's Avatar
Baby on board bump....^^^
