Steering Column Clock wise
I just bought this 00 LS and he said it was broken into or whatever and that everything was fixed. The steering wheel locks when I take out the key and the blinkers work fine. the thing is that its a little crooked and I can only move the steering wheel up and down slightly like a few CM up n down. the blinkers and the plastic piece are crooked clockwise is there anyway i can adjust this so it can be straight?? also one question with the locks, if the passenger lock switch is disconnected will the power locks still work?
Modified by colombian linx at 6:43 PM 3/3/2006
I have the same issue. Thieves man, when they broke the wheel lock it bent the column. Gotta replace it unless someone has any bright ideas
I haven't replaced mine yet cause I cannot justify the price yet.
sillyboybmxer
12
Jul 10, 2007 10:57 PM
Typical Lucas
Jan 27, 2003 11:26 PM
