Honda S2000 Honda S2000
1/8" toe out in degrees...(i promised i searched...
Old Mar 3, 2006 | 05:48 AM
95dc2's Avatar
Default 1/8" toe out in degrees...(i promised i searched...
....and searched and searched). i keep getting different answers. most threads refer to trig [soh cah toa], but even those answers vary. i have stock wheels and tires and need to know what 1/8" toe out will be in degrees. i've looked here (h-t) and s2ki. TIA
i don't mind being wrong or called out, etc...just would like a confident answer.
Old Mar 3, 2006 | 06:35 AM
Nishant's Avatar
Default Re: 1/8" toe out in degrees...(i promised i searched... (95dc2)
toe is not measured in degrees, only in length
camber is measures in degrees
Old Mar 3, 2006 | 07:36 AM
WowOzYouRock's Avatar
Default Re: 1/8" toe out in degrees...(i promised i searched... (Nishant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">toe is not measured in degrees, only in length
rofl
Old Mar 3, 2006 | 08:04 AM
95dc2's Avatar
camber is measures in degrees</TD></TR></TABLE>
ok. then what are all these threads about?
https://honda-tech.com/zerothread?id=1061318
https://honda-tech.com/zerothread?id=1167604
https://honda-tech.com/zerothread?id=1391199
https://honda-tech.com/zerothread?id=521378
Old Mar 3, 2006 | 09:57 AM
Nishant's Avatar
i was refering to when you go get an alignment done. all their scales measure toe in inches. they do not have dgrees. if you want to know how to convert, just read the threads you posted. the info is there
are you taking it to a shop that has it in degrees?
Old Mar 3, 2006 | 10:15 AM
95dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">i was refering to when you go get an alignment done. all their scales measure toe in inches. they do not have dgrees. if you want to know how to convert, just read the threads you posted. the info is there
are you taking it to a shop that has it in degrees?</TD></TR></TABLE>
yeah, my boy at the acura dealership said he needs all measurements in degrees. i've never actually done an alignment, so i guess i can only go by what he says.
Old Mar 3, 2006 | 12:37 PM
Mr. Projekt's Avatar
* B A N N E D *
AFAIK, toe is in degrees and minutes on a machine, as with factory specs.
Old Mar 6, 2006 | 09:59 AM
95dc2's Avatar
Default Re: 1/8" toe out in degrees...(i promised i searched... (Slideways2000)
can one of you math majors check my work?
https://honda-tech.com/zerothread?id=1546693
TIA
Old Mar 6, 2006 | 10:12 AM
* B A N N E D *
1/8" = 1.74 degrees per side or total.
If you want 1/8" total, its half that per side.
Old Mar 6, 2006 | 10:16 AM
95dc2's Avatar
thanks
eglude
Suspension & Brakes
30
Aug 21, 2008 10:21 AM
mikeycivic
Suspension & Brakes
Apr 3, 2007 01:01 PM
jayisnameless
May 21, 2004 10:34 AM
aznfab
Nov 24, 2003 10:24 AM
CivicSiRacer
May 12, 2003 03:18 AM
