Converting to 1 02 sensor
Old Mar 3, 2006 | 02:06 AM
Ak_ef9's Avatar
Default Converting to 1 02 sensor
I tried a seard but cant search 02 and when I search for oxygen sensor it only comes up with 6 thing.
I will be putting on a kamikaze header on my first gen b16. the stock header comes with 2 o2 sensors but I only want one so what can I do to convert it to only one? If you got any suggestions please include a link that would help thanks. I dont care about emissions since I have a seasonal waiver
Old Mar 3, 2006 | 02:13 AM
crxnj's Avatar
Default Re: Converting to 1 02 sensor (Ak_ef9)
You can just run 1 o2 sensor and splice both wires into one..But the motor would bog alot ..The correct thing to do is drill a hole and have an o2 bung welded on and run both of the o2 sensors..Or if you plan to convert to obd1 anyway you can do that and run (1) 4 wire o2 sensor..Also another option if having the ecu chipped to see no o2 sensors at all and just plug up the hole(s) on the exhaust manifold.
Old Mar 3, 2006 | 04:34 AM
mar778c's Avatar
Community Builder
Community Influencer
You have a couple of options. Like Mr.Speaker said you drill holes in your manifold or convert to obd1 or you can get your ecu chipped.
MiG-01
Apr 16, 2010 12:16 PM
Contender25
17
May 3, 2006 09:04 PM
som1_2race
Jun 11, 2005 02:47 PM
Norcalstoppy
Aug 4, 2002 09:33 AM
