Blown tranny. HOW?!
Blew my tranny today at the track. WTF went wrong? I preloaded the clutch and everything. 6k and feather it out, right when i got out the hole i dumped it then that's when it blows. Only on toyo ra1s, not even that sticky.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedDreamz.com »</TD></TR><TR><TD CLASS="quote">its a honda tranny get used to it if you are gonna go to the track.
What he said...
I have also killed a trans by wheel hopping on the street with pos tires. It only took once and it was only for as long as it took me to push in the clutch once i felt it start. It tore the final drive gear splines right off the shaft.
</TD></TR></TABLE>What he said...
cause when the tranny case is cracked where the bolt goes and like it makes a slight clunking noise. I meant nothing internally like all the little ****.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER »</TD></TR><TR><TD CLASS="quote">so how do you prevent blowing trannies?</TD></TR></TABLE>
Drive a unmodified d series.
