Honda S2000 Honda S2000
NEED HELP with TIRE SIZE!
Old Mar 2, 2006 | 09:42 PM
dc5 jared's Avatar
Default NEED HELP with TIRE SIZE!
alrite hondatech s2000 heads. i need your help once again.
im getting a set of staggered rims. here are the specs.
frnt: 16x8 +42
rear: 17x9 +42
(side note: my fenders will be rolled. and yes i know +42 is a low offset of s2k)
my question is what tire size should i run. i was thinking 225/45/16s and 245/40/17's
i would like some input/opinions.
thanks
Old Mar 2, 2006 | 10:11 PM
ahbongkadah's Avatar
Default Re: NEED HELP with TIRE SIZE! (dc5 jared)
Thats a very odd wheel size you have chosen. First off, why the 16/17 combo? And second, why 17x9 +42? If you are going to run a 17x9 wheel you need a higher offset, even with rolled fenders you may still rub.
I'm not bashing your choice, just curious as to why you decided to go with it
Old Mar 2, 2006 | 10:18 PM
dc5 jared's Avatar
Default Re: NEED HELP with TIRE SIZE! (ahbongkadah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahbongkadah &raquo;</TD></TR><TR><TD CLASS="quote">Thats a very odd wheel size you have chosen. First off, why the 16/17 combo? And second, why 17x9 +42? If you are going to run a 17x9 wheel you need a higher offset, even with rolled fenders you may still rub.
I'm not bashing your choice, just curious as to why you decided to go with it </TD></TR></TABLE>
well these rims are discountinued they are specified for nsx. there are only a handful of these sets in north america. probably only 4-5 sets. im pretty lucky to get used set.
Modified by dc5 jared at 7:36 AM 3/3/2006
Modified by dc5 jared at 9:23 PM 3/7/2006
Old Mar 2, 2006 | 10:30 PM
Ok that makes sense then. With 17x9 +42, you will need to roll and run lots of neg camber. (maybe even cut the inner lip of the fender)
Also for the front, if you want 225 go with a 225/50/16. Not 225/45/16.
I don't think you will have any problems, there is a member on s2ki running enkei rpf1 in 17x9 +45 on all 4's. And he regularly tracks his car so i'm guessing it doesn't rub. Fender mods were obviously done to make it work though
Old Mar 2, 2006 | 10:37 PM
dc5 jared's Avatar
why do u suggest 225/50's over 225/45's??
Old Mar 2, 2006 | 10:44 PM
because thats the correct size
225/50/16 to retain the closest size to stock tire height. (i'm going by ap1 sizes)
stock= 205/55/16 tire wall height is 205 x .55= 112.75
225/50/16 = 225 x .5 = 112.5
225/45/16 = 101.25 &lt; as you can see your orig set up is about 11mm off from stock tire wall height.
Also if you are going 225f and 245r are you going to run a stiffer front sway bar? Because your car will be more induced to over steer with this set up. And if you have an ap1 like me, thats probably that last thing you want.
Old Mar 6, 2006 | 05:33 PM
dc5 jared's Avatar
anymore input?
Old Mar 6, 2006 | 07:54 PM
pwrofdrm's Avatar
Does this answer your question?
Old Mar 7, 2006 | 12:10 PM
dc5 jared's Avatar
Default Re: NEED HELP with TIRE SIZE! (.no tork.)
i believe those are 205/55/16's es100s.
is that manny's car?
Old Mar 7, 2006 | 12:12 PM
c17r15's Avatar
did you get those champ white/bronze MF10's from ICB?
Old Mar 7, 2006 | 12:22 PM
dc5 jared's Avatar
Default Re: NEED HELP with TIRE SIZE! (c17r15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c17r15 &raquo;</TD></TR><TR><TD CLASS="quote">did you get those champ white/bronze MF10's from ICB? </TD></TR></TABLE>
ding ding ding!
Old Mar 7, 2006 | 12:31 PM
Mr. Projekt's Avatar
* B A N N E D *
225/50/16 and 255/40/17.
Old Mar 7, 2006 | 12:40 PM
dc5 jared's Avatar
Default Re: NEED HELP with TIRE SIZE! (Slideways2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slideways2000 &raquo;</TD></TR><TR><TD CLASS="quote">225/50/16 and 255/40/17.</TD></TR></TABLE>
if i dont get 205/55/16s es100's im debating on getting 225/50/16s as u said.
but i doubt ill get 255's in the rear due to the aggressive offset. ill stick to 245/40/17s
thanks for the input....keep it coming guys.
Old Mar 7, 2006 | 11:24 PM
liam821's Avatar
25 Year Member
with a 9" wide rim, id say run the larger 255 tire. I run 245s on my stock 16" rims.
liam
Old Mar 7, 2006 | 11:37 PM
dc5 jared's Avatar
Default Re: NEED HELP with TIRE SIZE! (liam821)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 &raquo;</TD></TR><TR><TD CLASS="quote">with a 9" wide rim, id say run the larger 255 tire. I run 245s on my stock 16" rims.
liam</TD></TR></TABLE>
id love to run 255's in the rear...but its easier said than done. especially if the offset is +42 and im planning to slamm the car.
Old Mar 8, 2006 | 09:32 AM
CLOUT's Avatar
whaddup jared
225/50/16 and 245/4017 bro.
225/45 would be a thin tire for the front. keep like the stock ap1 size's height as mentioned above i believe.
congrats!...sucks that it might rain sunday i dunno if imma got o the meet if it does.
Old Mar 8, 2006 | 04:57 PM
dc5 jared's Avatar
Default Re: NEED HELP with TIRE SIZE! (GDPzS2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GDPzS2000 &raquo;</TD></TR><TR><TD CLASS="quote">whaddup jared
congrats!...sucks that it might rain sunday i dunno if imma got o the meet if it does.</TD></TR></TABLE>
thanks for the input geoff....im mostlikely going to run the 225/50/16s and 245/40/17s
hope u can make it.
Trevor Donald
Honda Civic (2001 - 2005)
Nov 6, 2018 11:35 AM
JDMFreak_DC2
Jun 25, 2009 03:47 AM
GO-FIGHT-KILL
Jul 14, 2008 01:31 PM
migs
Apr 17, 2003 01:48 AM
Double 06
Apr 12, 2002 04:22 PM
