ExplicitSpeed360's rebuild project JDM H22 with F22/H23 crank and rods, 2.3L Stroker!
Old Mar 2, 2006 | 08:56 PM
ExplicitSpeed360's Avatar
Banned.
Default ExplicitSpeed360's rebuild project JDM H22 with F22/H23 crank and rods, 2.3L Stroker!
The weekend before last I spun a bearing. Ran good until I missed 4th gear and still everything was fine. On the way home ran same until I got a few miles from my house and knock knock...whos there? sure enough I look and mr spun bearing. Had it towed home sure enough cyl 3. I am taking the engine out this weekend early next week. I made a few phone calls and got the build sketched out. I will be rebuilding the engine with a F22/H23 crank and rods on a budget but done wise as long as everything mics out ok. I will post pictures of the de construction and rebuild this needs to be done within this month. The F22/H23 crank and rods are stout pieces from the factory. I am hoping for 200+ whp and 165+ ft lbs or torque with the stock JDM h22 cams p28 crome. As another setup similar just made 240 whp and 170+ ft lbs or torque. This is my daily driver.
The build:
93 JDM H22 50k on it (keepin the stock used rings) gotta love FRM sleeves
F22 crank and rods 2.3L
ARP rod bolts
Knife edge crank by me to clear squirters
Balanced
I have 30k mill of the head already and SS replacement valves in it. Along with my own Full PnP job. My compression should be in the area of 11.2-11.4-1.
Back to square one: OLD DYNO
184 whp @ 6900 rpm and 158 ft lbs or torque at 3200 rpm
Modified by ExplicitSpeed360 at 9:42 PM 3/4/2006
Old Mar 2, 2006 | 10:13 PM
Old_Honda's Avatar
Default Re: ExplicitSpeed360's rebuild project JDM H22 with F22/H23 crank and rods, 2.3L Stroker! (ExplicitS
http://www.imageshack.us/ , this should be a cool build .
Old Mar 2, 2006 | 11:32 PM
beyondspexj's Avatar
grab some itb's while your at it.
Old Mar 5, 2006 | 11:38 AM
si0385.'s Avatar
Default Re: (ExplicitSpeed360)
looking good man
#'s arent too bad either
Old Mar 9, 2006 | 02:59 PM
Banned.
Default Re: (beyondspecs_jamar)
Engines out, and dissembling it and gathering parts...
Old Mar 9, 2006 | 03:01 PM
Jonathan_ED3's Avatar
Why not go h2b while you're at it? It'd definitely rip!
Old Mar 9, 2006 | 03:05 PM
Banned.
Default Re: (Jonathan_ED3)
with the B series tranny we are talking about tenths not seconds...plus I have had no problems with my jdm H lsd tranny. Streetable and reliable...
Old Mar 9, 2006 | 03:07 PM
The before/after times i've seen have gained a couple MPH in the trap speeds....more important IMO than actual E.T.
for the H series...it's still a great engine/transmission combo.
Old Mar 9, 2006 | 03:32 PM
Banned.
ya I am runnin constant trap speed of 103/104 mph on hankooks soon to be a lil higher my guess 105-109 mph... which in theory should be high 12s with some sticky DR stuff on an ideal 1.8-2.0 60' time...
My best run to date woulda been my 14.4 @ 80 mph missed shift where did my 23 mph go? lol
The car is just a monster top end and likes to play catch up...I had the car pretty much down...I had no muffler 2.5" exhaust out the passenger side before the rear wheels and was losing the power down low and off the line with no muffler... I ran a 14.0 @ 102 with stock header and 2" exhaust with a cherry bomb end of last season this was before tuned on the dyno too. That was too much restriction but some is needed....
As you can see on the exhaust ports "We be runnin a lil rich" 10s was the A/F ratio after 4k rpm lean that out and 190 whp would be easy had on the dyno... Just goes to show you how our PnP jobs stack up because the head is stock minus a mill and our PnP job. JDM p13 spoon chip was thrown out the window and the p28 crome will be welcomed in...
http://www.ExplicitSpeedPerformance.net
Modified by ExplicitSpeed360 at 4:47 PM 3/9/2006
Old Mar 9, 2006 | 03:36 PM
Chase's Avatar
Cant wait to see wat it does.
Post alot of progress pics
Old Mar 12, 2006 | 01:11 PM
Banned.
Default Re: (EF8kid)
Got rid of the charcoal canister and placed the fuel filter more out of the way from harm...doing a wire tuck also running the wires either in the rails or under them...fuse box going to be hidden...and of course the vacuum hose box will be gone...
Old Mar 12, 2006 | 03:53 PM
HondaCivicSiR1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExplicitSpeed360 &raquo;</TD></TR><TR><TD CLASS="quote">Engines out, and dissembling it and gathering parts...
</TD></TR></TABLE>do you have your car on milk crates?
Old Mar 12, 2006 | 05:33 PM
Banned.
Default Re: (HondaCivicSiR1)
Milk crates? lol cmon' i got some fabbing skills lol handmade diamond plate steel stands...
Old Mar 12, 2006 | 05:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExplicitSpeed360 &raquo;</TD></TR><TR><TD CLASS="quote">Milk crates? lol cmon' i got some fabbing skills lol handmade diamond plate steel stands...</TD></TR></TABLE>lol i'm just messing with you bro looks good and good luck finishing your build
Old Jul 25, 2006 | 12:18 PM
Ray-mond's Avatar
How is ur stroker motor going any updates???
I've been thinking of going this route myself.Might be to much stroke for a 200 shot
Formally known as 1Guamracer.
Old Jul 25, 2006 | 01:14 PM
user 72830283's Avatar
damn..this looks like something i'd see on cb7tuner.com hehe but sounds like a nice build..any predictions on what kinda numbers you'd be putting down..?
x22xhyper
Sep 18, 2008 06:42 AM
ExplicitSpeed360
Mar 2, 2006 06:02 PM
Krnbk2
Jul 10, 2004 09:18 PM
DLB1994
Dec 2, 2002 11:41 PM
