Still having problems
Old Mar 30, 2002 | 07:20 AM
zCivic's Avatar
Default Still having problems
Checked my ECU and engine grounds there all good. I double checked my TPS switched them back and forth. When I connect straight to the Distributor c1 and c2 it starts when I run the wires from the B plug reverse B10 to C2 and B12 to C1 it starts will throw codes 4 and 7 again. When have it wired correctly B10 to C1 and B12 to C2 it just cranks, hits for a second and then Dies out.
Old Mar 30, 2002 | 09:21 AM
EF'n's Avatar
Default Re: Still having problems (zCivic)
i had a similar thing happen, mine was a plugged cat. worth a shot.
Old Mar 30, 2002 | 11:15 AM
zCivic's Avatar
Default Re: Still having problems (revhardracing)
Unfortunately I no longer have the cat so thats not it. Was that your only problem that you had was the cat???
ef_for_life
29
Jan 26, 2007 06:12 PM
xjohnx
Sep 26, 2006 06:29 PM
jdmhatch
Jul 4, 2002 02:40 AM
Isaac
Mar 1, 2002 07:05 PM
