rear trans mount problem HELP!
no i was trying to use the gsr one. so lemme get it right... to the people who have done this swap... i need a rear tranny bracket from a ls motor?
they should be the same size( the 90-93 ls and the gsr) the 90-93 is just shaped different so it lines up with the mount , the 90-93 mount curver to the side were as the gsr is straight
hmmm. im just wondering, because with the gsr one my hasport mount has a lot of play on each side. n e one do this and run into the same issue????
Modified by ef9typer at 9:55 PM 3/2/2006
you also need to swap the mount on the driver's side end of the engine for one from 90-93 Integra - Acura part no. 11910-PR3-010
88_T-Rex
Aug 2, 2005 07:25 AM
BlueShadow
Jun 22, 2004 06:04 PM
