91 ls motor and 95
Old Mar 2, 2006 | 07:04 PM
lilmonkey's Avatar
Default 91 ls motor and 95
Hey you guys think a 91 ls integra motor fit on a 95 integra ls car. I have the ls transmission but i just wanna know does it fit
Old Mar 2, 2006 | 08:21 PM
bks84's Avatar
Loved
jesus...
yes it will fit.
the 91 is obd0
the 95 is obd1
probably not going to pass state inspection since its illegal to have an older engine in a newer car.
will it fit? yes.
does it make sense to do so, no, not in my book
Old Mar 2, 2006 | 08:22 PM
Keats97turboteg's Avatar
Default Re: 91 ls motor and 95 (lilmonkey)
He is right it will fit.
Old Mar 3, 2006 | 12:39 AM
crxnj's Avatar
Default Re: (4sd4dr)
yeah it will work..Re-use the 95 integra's distributor though..And 95 integra B18b intake manifold as it is better then the 90-91 ,,Also you'll loose power because the 90-91 B18a's have less agressive cams then the 92+B18a/b's..And re-use the obd1 injectors because obd1 injectors are saturated and obd0 are peak and hold and would require you to wire in a resistor box from a 88-91 civic/crx si/hf or 90-91 integra..
Old Mar 4, 2006 | 12:42 PM
bks84's Avatar
Loved
the resistor box from 86-89 integras will work as well, but do what mr.speaker said, keep most of the electronics from the 95's ls and swap it over, also swap over those cams too.
vietrance
May 9, 2011 10:33 PM
swtch7
Aug 25, 2005 06:30 PM
