16Zck Internals---------High Compression
Old Mar 2, 2006 | 07:02 PM
iceman95's Avatar
Default D16Z6 Stock Internals---------High Compression
Guys I am planing to build a motor D16Z6 with stock internals and I want to use a the CR of 12:0,is it okay for the stock internals,if not please tell me the highest possible on stock internals........THANKS
Old Mar 2, 2006 | 07:04 PM
EX-T's Avatar
Default Re: D16Z6 Stock Internals---------High Compression (iceman95)
You're not getting that high of a compression ratio with stock internals!
Highest you'll get is like 9.7-9.8:1 by milling head and thinner head gasket!
Old Mar 2, 2006 | 07:05 PM
iceman95's Avatar
Default Re: D16Z6 Stock Internals---------High Compression (DSeriesBKilla)
I am using the p29 pistons....
Old Mar 2, 2006 | 07:22 PM
iceman95's Avatar
bump.........!!!!!!!!!!!!!
Old Mar 2, 2006 | 08:58 PM
canis's Avatar
well im not quite sure, buts its just a safe beet, to upgrade anyways, i built a SC Z6, and did the hole upper and lower, full rebuild, and its totaly fine (though not like i wouldnt expect it to be) but be on the safe side if you can man
Old Mar 2, 2006 | 09:24 PM
Stop the Beast's Avatar
How do you plan on running 12:0:1 with stock internals? Mill the head and thinner head gasket?
The compression isn't going to kill stock rods and pistons. Unless you're building a race only car try and stay below 12:0:1 so you can get a decent tune on 91-93 octane fuel.
b00stedOne
Jul 28, 2014 09:56 AM
1SIKZ06
Mar 4, 2009 12:59 PM
ProjectBB6
Mar 13, 2008 09:24 AM
fastaccord94lx
May 19, 2003 05:51 PM
