Shock Tower pinouts for HF and Si
I need to get a Si engine harness to work with the CRX HF. I was told the shock tower plugs have different pinouts.
Anybody have these pinouts or know where to get them? I've searched long and hard.
-Shane
-Shane
i moved the pins for the injector resistor yellow/blk wire and i got 12v at my injectors, which i did not have before. i just do not know what other pins may need to be rearranged
shock tower diagram for HF engine harness side driver shock tower plug:
[1][2]
[3][4][5][6]
[7][8]
1. IACV -Blue/Yellow
2. IGN. Cont. Mod. Dizzy -White
3. EGR - Yellow
4. Injector #4-Yellow
5. Injector #1-Brown
6. 12v power for resistor box - Yellow/Black
7. Injector #2-Red
8. Injector #3-Light Blue
so what wire does the HF harness have that the SI harness doesnt have? do u have the color pinouts for the other side, i need the chassis side of the pinout too
the pinout will be a mirror image for the chasis side plug. like i said its easier (plug n play) if you use a stock hf harness.
..[1][2]
[3][4][5][6]
..[7][8]
1. inj2 -red
2. inj1-brown
3. inj3-blue
4. inj4-yellow
5. grn therm. valve-blk
6. sig. therm. valve-light blue
7. IACV-blue/yellow
8. 12v for resistor box-yellow/blk
ok because i had no power all day until i decided to try n jump those and had 12v at my injectors. also i had continuity at all 4 injector clips and ecu inj2 pin number A3
and ok so the solid blue (6) that goes to the small 2 pin connector on the other side of the engine harness almost, is the thermo valve from the d series?
yea i gotcha. so i just need to match all those pins and it will run if i have no other wiring issues, correct? and also an obd0 harness does not come with an ect switch does it?
is ECT not the brown sensor on the back of the block for a b series, right next to the thermostat. and if so i do not have a connector for it, unless the IACV is not the same type of connector on the SI harness?
like does the switch that i think is IACV really supposed to be on my ECT? and do i actually have the same type of connector from d series to b series IACV? or do i need to add a connector.
and while were at it, the yellow and green wires on a civic si harness are reverse lights, no?
