Walbro fuel pump question
Old Mar 2, 2006 | 05:30 PM
CoolRedXylophone's Avatar
Default Walbro fuel pump question
im going to replace the fuel pump on my hf becuase the old one is broken. im planning on doing a b16 swap and i might go turbo eventually and i know that turbo requires a high flow fuel pump. my question is would a high flow walboro 225 be harmful overkill to my 60 hp hf engine? it would be great to just be able to put the high flow pump in there and not have to worry about it in the future
Old Mar 2, 2006 | 07:08 PM
Reelizmpro's Avatar
Default Re: Walbro fuel pump question (CoolRedXylophone)
****, even a 190 would be overkill for the HF engine but if you plan on going B16, the 190 would be fine. I've noticed most complete turbo kits already come with a 255.
Old Mar 2, 2006 | 07:46 PM
1crazysir's Avatar
Default Re: Walbro fuel pump question (Reelizmpro)
All a high flow pump does is make sure you always have fuel, if u have a fuel pressure regulator, that's what determines how much fuel is going into your motor.
The pump just makes sure the gas is always there.
thunderboy
Jun 20, 2011 03:52 PM
mrDFWmechanic
Jun 16, 2005 07:05 PM
Griffins_Importuning
Jul 21, 2002 07:15 AM
