throttle cable
Old Mar 2, 2006 | 04:40 PM
eltigre's Avatar
Default throttle cable
how do i take out my throttle cable on my 90 civic 4dr?
Old Mar 2, 2006 | 05:08 PM
EL Vap133's Avatar
Default Re: throttle cable (eltigre)
Very easily, just look under the dash and you'll see how it's attached to the gas pedal, you don't even needs tools.
Old Mar 3, 2006 | 07:21 PM
eltigre's Avatar
Default Re: throttle cable (EL Vap133)
i tried..but i cant get it off..and its pissin me off cus i know its my prob. yet i cant fix it..
Old Mar 4, 2006 | 10:18 AM
eltigre's Avatar
ne1??
Old Mar 4, 2006 | 12:06 PM
thesmogman's Avatar
If it is like my 88 crx there is a white clip that snaps into the pedal assembly. Pop it out with a small screwdriver and the cable should end up in your hands.
Look at the new one to see what the clip looks like.
Just remember that the cable needs a little play!
Old Mar 4, 2006 | 01:31 PM
eltigre's Avatar
Default Re: throttle cable (thesmogman)
ok...
would that be the problem why my car keeps revving??
or is it a vacuum or another cable or what??
any help greatly appreciated
Old Mar 4, 2006 | 01:48 PM
PINKS's Avatar
I want a CRX tattoed on my butt
If youre car is spiratically revving, up and down up and down and is consistant, you either have a nice vacuum leak (check EVERYTHING), or your tps is out of adjustment, or your iacv on the back of the intake manifold is clogged and needs a clenaing or needs to be replaced
If your idle is bouncing, its not your throttle cable
Old Mar 4, 2006 | 01:55 PM
eltigre's Avatar
Default Re: throttle cable (TurblowEF)
but when i tighten my cable...my car starts revving
and when i loosen it..the car stops revving and the idle drops
90ZCREX
Nov 5, 2011 08:44 AM
THE GREEN CRX//
Feb 12, 2011 01:18 PM
90efsedan
Nov 8, 2009 06:20 PM
delamission
Jan 21, 2006 03:15 PM
EKtypeRhaTcH
Jul 6, 2003 06:46 PM
