**JDM TRANSMISSION from Prelude Type-S (H22A ATTS LSD TRANSMISSION)**
JDM TRANSMISSION from Prelude Type-S (ATTS LSD TRANSMISSION)
This tranny comes directly from a 1999 Prelude Type-S JDM. This tranny is equiped with the ATTS LSD system. It comes straight off the engine straight from Japan, I never used it and its got under 60k on it!! If you like cornering like a mad man and want to feel like your driving a RWD with your FWD then this is the transmission for you! Awesome Transmission upgrade or replacement for stock!!
INCLUDES ATTS module and ATTS ECU
NEW PRICE: 700$
tranny code: M2U4-1000314
casting# 4000218
atts ecu module code: 48310-p5p013
This part is great conditon with under 60,000 KM's on it!!
call me or message me
- CALL ME: Einick 514-570-5128
This is an ATTS LSD system, it does not only lock the differential like standard LSD systems, it does much more. So to answer your question, YES, you have to use the whole system together to make the ATTS LSD work, OR you can just use the tranny without the ATTS LSD but you will have to make a modification; there is a special drive shaft piece you can build or have built to replace where the ATTS module would have been...
FYI...ATTS means: Active Torque Transfer System
A relatively new technology is the electronically-controlled active differential. A computer uses inputs from multiple sensors, including yaw rate, steering angle, and lateral acceleration and adjusts the distribution of torque to compensate for undesirable handling behaviors like understeer. Thus providing for excellent traction in and out of turns, making for impressing road handling....
MTL514
Mar 29, 2011 07:27 PM
MTL514
Canada (Sales)
Dec 11, 2005 01:07 PM
MTL514
Canada (Sales)
Jun 13, 2005 03:12 AM
