Yamaha Technical Bulletin #M2006-003
Yamaha Technical Bulletin #M2006-003 This is another Technical Bulletin pertaining to the YZF-R6 and FZ6.
Technical Bulletin #M2006-003 issued 02/24/06
1999-2005 YZF-R6 and 2004-2005 FZ6
Drive Sprocket Retaining Nut and Lock Washer Replacement
INTRODUCTION:
Symptom:
In some cases, the drive sprocket retaining nut lock washer can allow the nut to rotate just enough to reduce the clamping force resulting in fretting the drive sprocket retaing nut and lock washer.
Remedy:
Replace the drive sprocket retaining nut and lock washer on all units in the affected range regardless of their warranty status.
AFFECTED RANGE:
1999-2005 YZF-R6:
RJ04E-0000015-0028429
RJ04Y-0000006-0002931
RJ06E-0000012-0030477
RJ06Y-0000004-0006432
2004-2005 FZ6:
RJ08E-0000005-0005165
RJ08Y-0000003-0000810
INTRODUCTION:
Symptom:
Remedy:
AFFECTED RANGE:
1999-2005 YZF-R6:
2004-2005 FZ6:
OmgDelSol
Apr 15, 2014 08:29 AM
