CV Shafts
you need a manual driver side axle and a halfshaft. an intermediate shaft is also called a halfshaft or midshift, it bolts to the block and the spline of the axle goes into one end of the halfshaft
Modified by raceACCORDingly at 12:57 AM 3/3/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfish »</TD></TR><TR><TD CLASS="quote">The pass side axles are the same auto & stick</TD></TR></TABLE>
they are actually slightly different. the bearings on the spider gears are shaped differently. but i don't think there are any negative side affects to using an auto pass side axle.
xtremeness101
Jan 17, 2006 07:17 AM
