N20 for my rsx help
Okay I just want to know what I would need to run a zex N20 kit (DRY).
I have a 65 shot in it.
I have no mods done to my engine.
What will I need to run this? thanks for your input
You can't run a dry kit safely on the RSX. You will need to run a wet kit which controls fuel also.
If you already have the dry kit and you are asking what you will need to run it, the answer is Hondata K-Pro which is quite expensive. This will allow you to control the fuel and retard the timing when the nitrous engages. Otherwise say boom to your A2.
You can run whatever you like, but I'm just telling you what will and will not destroy your motor. A dry shot will not work with the RSX, you need a wet shot. If you plan on using a dry 65 shot, you will need some type of engine management to retart timing and add fuel when the nitrous kicks in.
It is much simpler to just start with a wet shot, not to mention safer.
Read this sticky, its quite informative.
http://forums.clubrsx.com/showthread.php?t=67774
http://forums.clubrsx.com/showthread.php?t=134649
Okay I just found out that I cannot run a dry kit because of the internal fuel preasure regulator. I am going to so if anyone will trade me dry for wet or if I have to sell the dry and buy a wet I will thanks for the help
Mattb16teg
Dec 18, 2005 08:25 PM
