Fan doesn't blow
Old Mar 2, 2006 | 09:35 AM
in4mation's Avatar
Default Fan doesn't blow
So I decide to use the EG today and since it was raining, I decided to use the A/C to defrost the windows. When I turned on the fan to #2, nothing would happen. No air would flow through the vents. When changing the settings on the vents for the different airflow positions, it worked because I could hear the motor changing the position. However, when I turn on the A/C button, it illuminates green and I can hear the A/C turn on, but since no air flows through the vents, it won't cool anyways. What problem do I have with the air not flowing through the vents? How do I fix this?
Old Mar 2, 2006 | 10:54 AM
Syndacate's Avatar
is it only on setting #2? Which settings did you change, just the placement settings, or did you change the ammount settings as well? If it works only 4 only, it could be the resistor (which usually don't go bad), if not, your vent pipes could be stuck (inside)
Old Mar 2, 2006 | 10:58 AM
in4mation's Avatar
Default Re: (Syndacate)
It doesn't blow on all settings 1-4. It was just blowing fine like a few minutes. I turned it back off because I had to open the window for something. Then I tried to turn in back on an it wouldn't blow any air.
Old Mar 2, 2006 | 10:59 AM
White95SiHB's Avatar
Default Re: Fan doesn't blow (in4mation)
I don't remember if the fans have their own fuse or not. So check the fuses. It's also possible the fan is dead and will need replacing. PM Outrun, I think he replaced his fan recently.
Old Mar 2, 2006 | 11:37 AM
in4mation's Avatar
Default Re: Fan doesn't blow (White95SiHB)
Ok, I'll try that. How much are replacement fans anyways??
Old Mar 2, 2006 | 11:39 AM
amckee's Avatar
I'm pretty sure they're over $100.
Old Mar 2, 2006 | 05:41 PM
Syndacate's Avatar
Yeah, with new information, sounds like your fan motor crapped out...
Not sure replacement cost, but I'm sure u can find one at a junkyard, that'd be ur best bet anyways..
Old Jul 17, 2007 | 12:29 PM
B_CRUZ!'s Avatar
sorry to bump an old post but my fan only works when the engine is off.
Anybody have any ideas why it is doing this?
smackdown
Aug 16, 2010 09:35 AM
DaveSi677
12
Dec 10, 2008 06:36 AM
Tricid
Jun 28, 2006 07:36 PM
SPOT..
Mar 23, 2006 02:30 PM
Milano4
Jun 9, 2004 12:15 PM
