1999 accord alarm wiring diagram
Old Mar 2, 2006 | 09:31 AM
truckramrod's Avatar
Default 1999 accord alarm wiring diagram
I tried searching but couldn't find anything so here it goes:
I am about to install an alarm in my friends 99 accord coupe. does anyone have any diagrams or lists of the ignition system and power door lock system so I can do the starter kill and keyless entry.
the cars a 4cyl/4spd auto. Any help is apprectiated! That information might be a good idea to make a sticky of.
Thanks everyone!
Old Mar 2, 2006 | 10:25 AM
B18C_EJ8's Avatar
http://www.bulldogsecurity.com
Old Mar 3, 2006 | 06:11 AM
MotoCARR's Avatar
Default Re: 1999 accord alarm wiring diagram (truckramrod)
12volts white + ignition harness
Starter black/white + ignition harness
Notes: If doing starter kill, must interrupt the wire between the keyswitch and the fusebox, not between the fusebox and the starter, to keep the check engine light from coming on.
Second Starter N/A
Ignition black/yellow + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory yellow + ignition harness
Second Accessory white/black + ignition harness
Keysense
Power Lock black/blue - passenger side fuse box
Notes: in a green 20 pin connector.
Use black/white for lock and green/red for unlock on LX models without factory security. These wires are located in a two pin gray connector by the front of the drivers side fuse box.
Power Unlock orange - passenger side fuse box
Lock Motor white/red driver side fuse box
Unlock Motor driver side fuse box
Notes: yellow on the EX and lt. green/red on the LX
Parking Lights+ red/black driver side fuse box
Parking Lights- red/yellow steering column
Notes: Only available on the EX model.
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light green/black + driver side fuse box
Door Trigger black/white - passenger side fuse box
Notes: In a green 4 pin connector.
Dome Supervision use door trigger
Trunk/Hatch Pin orange - drivers kick panel
Notes: Above the hood release in a gray 18 pin connector. On the DX & LX models, also found in a 2 pin connector behind the drivers fuse box.
Hood Pin yellow/red or yellow - hood pin switch or
Notes: On the EX models it is in a green plug next to the passenger side fuse box. On the LX models it is at the keyless/security unit, if equipped, which is attached to the driver side underdash panel.
Trunk/Hatch Release white/red + drivers kick panel
Power Sliding Door
Factory Alarm Arm
Notes: Arms and disarms with the door locks on the EX models. The LX models arm only with the factory transmitter.
Factory Alarm Disarm
Disarm No Unlock blue -
Notes: On the EX the wire is located at the drivers power window switch, on the LX the wire is at the keyless/security unit which is attached to the drivers underdash panel.
Tachometer blue tach test connector
Notes: The tach test connector is located behind the battery on the 4 cylinder, and on a bracket attached to the drivers side strut tower on the 6 cylinder motor. The tach test connector is a white 2 pin connector, and may be covered by a black rubber boot.
Wait to start
Brake Wire white/black + brake pedal switch
Parking Brake
Horn Trigger lt. green/blue - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556HW
Alternate Part1 #: 556UW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes:
Old Mar 5, 2006 | 07:00 PM
I appreciate your guy's help.
Hey B18C_EJ8
are you familiar with using those T-harnesses?
Please anyone who is familiar with those harnesses please try to contact me on AIM, my screenname is Vorteczq8
kroze
Honda Civic (2006 - 2015)
17
Feb 9, 2014 01:57 PM
Domani99
Audio / Security / Video
23
Apr 4, 2011 05:11 PM
hondacoupe05
Dec 31, 2008 10:21 AM
alex_s817
Jul 27, 2006 01:57 PM
LI_mechanic
Feb 20, 2006 08:49 AM
