Brakes write up
Old Mar 2, 2006 | 08:33 AM
ALTEZZAJOVY's Avatar
Default Brakes write up
Going to do my brakes and I need a write up. Does anyone have a manual they can post for doing the brakes. . .Thanks
Old Mar 2, 2006 | 12:25 PM
Default Re: Brakes write up (ALTEZZAJOVY)
anyone. . ..
Old Mar 2, 2006 | 01:34 PM
Deo's Avatar
Deo
Define "doing"
Old Mar 2, 2006 | 01:54 PM
DC_RaceR's Avatar
Default Re: Brakes write up (Deo)
1a. Loosen lug nut a little.
1b. jack up car..
2. place on stand
3. take lug nuts off
4. take tire off
5. take the buttom bolt of the caliper out
6. pull caliper up
7. pull out old pads
8. place quick seals on.. ( the blue stuff )
9. place new pad in place
10. close caliper back on
11. might need to push caliper back in.
12. bolt the bolt back on
13. place tire back on
14. bolt lug nuts back
15. jack car back up to take out stand
16 Done one side
Pads in the back almost the same why except you have to take out both caliper bolts.
If you have Drum then you on your own...
Old Mar 4, 2006 | 12:27 AM
with the rear you have to rotate the pistons back. .
BrakeExpert
Suspension & Brakes
Aug 27, 2008 10:34 AM
MDM
Aug 27, 2007 11:22 AM
longcarbine
Honda Civic (2001 - 2005)
Mar 30, 2007 01:53 PM
roundworldsobig
Sep 1, 2006 08:08 AM
