--Need HELP With Rear Brake Drum--
Old Mar 2, 2006 | 08:16 AM
89sicivic's Avatar
Default --Need HELP With Rear Brake Drum--
after bleeding my brakes and noticing that the fluid keeps getting lower after using the brakes...i noticed a puddle coming from the rear drivers side rear drum brake my question is how do you get the drum off and what inside could be causing it to leak this much brake fluid?
Old Mar 2, 2006 | 10:01 AM
Tyson's Avatar
Default Re: --Need HELP With Rear Brake Drum-- (89sicivic)
just make sure the parking brake is off, the drum should just pop off. you might have to pry it out carefully, but there should be nothing else keeping the drum on.
your wheel cylinder (rear brake piston) is probably leaking. replace it immediately.
globy123
Sep 21, 2009 01:07 PM
globy123
Sep 21, 2009 11:56 AM
immajackuup
17
Jun 2, 2008 09:46 AM
