motor mounts for ls swap
Old Mar 2, 2006 | 07:51 AM
92CiviC4dr's Avatar
Default motor mounts for ls swap
do i need motor mounts for an LS swap in a 92 civic sedan?
Old Mar 2, 2006 | 07:58 AM
dohcdelsol's Avatar
Default Re: motor mounts for ls swap (92CiviC4dr)
yes
*I BELIEVE* you need a delsol vtec mounts or integra mounts
you can get away with the civic passenger mount.
search
DAxsi16's Avatar
yea i would prefer u get motor mounts . u could howeevr use your mounts for ur single cam but it wont hold for long could dent ur hood bend ur frame etc seen it happen . so i would jus get mottor mounts only run about 150 worth it
Old Mar 2, 2006 | 08:04 AM
dohcdelsol's Avatar
Default Re: motor mounts for ls swap (ej8jerk)
From the GodFather himself
B18C5-EH2
First of all mounts:
For the timing cover side mount you will need to get the cast-iron bracket from any 1994-2001 Integra GS-R and also the aluminum mount as well. You can use the mount from a Del Sol VTEC as well, but not the 99-00 mount because it is totally different.
For the rear mount you will need to use a 1994-2001 Integra rear bracket. The actual rubber mount that bolts to the rear subframe can be the stock civic one. Check the 99-00 mount first and see if it will work too though before you go out and buy an Integra one. I used an Integra rear bracket on my fiancee's B16A2 swap in 1999, but the stock 99-00 one might work too.
The topside tranny mount can be the Civic VX one - it is the same thing.
The front mounting brackets need to be from an Integra 1004-2001, but if you want to keep A/C then get the A/C bracket for a Del Sol VTEC model. the actaul mounts that bolt to the underside of the framerails need to be the stock Civic ones.
I would also insert the energy Suspension mount inserts while you've got the mounts out.
atmosphere
15
Oct 7, 2025 03:53 PM
Grams0wnsyouz99*
Nov 8, 2005 11:10 AM
Got Utensils
Mar 18, 2004 05:08 AM
CW96
Dec 6, 2003 03:58 PM
swiftstyles
Nov 19, 2003 04:58 PM
