Vtec ground, which pin ?
Old Mar 1, 2006 | 09:27 PM
RCautoworks's Avatar
Default Vtec ground, which pin ?
I can't believe no one ever answered this before in previous topics. I don't want to hear I can ground the solenoid to anywhere because I need to wire it to the ecu. I need the pin location on the ecu. Thanks.
Old Mar 2, 2006 | 10:41 AM
jacoop86's Avatar
Default Re: Vtec ground, which pin ? (90blackcrx)
vtec solinoid ground doesnt go to the ecu. it is grounded along with the rest of the engine harness either on the block or frame. i dont believe there is a ecu pin for it, and if there is it would be dumb to run a wire to the ecu just to ground it to the frame later. am i missing something??? why do you need it ran to the ecu?
Old Mar 2, 2006 | 11:37 AM
dr_latino999's Avatar
Default Re: Vtec ground, which pin ? (jacoop86)
The ground is the thermostat housing. (According to the wiring harness in my car)
88_hatch_ls
Apr 8, 2014 02:55 AM
swappyturbo
Oct 28, 2008 03:26 AM
lude98SH
Aug 30, 2007 08:55 AM
93cavRS
Oct 10, 2006 12:25 PM
suckawillis
Oct 5, 2005 09:00 AM
