OEM catalitic conv. on 90 Si - welded or bolted?
Old Mar 1, 2006 | 08:58 PM
( o )( o )'s Avatar
Default OEM catalitic conv. on 90 Si - welded or bolted?
On my 2000 Si, the catalytic convertor from the factory is a bolt-on unit. I went to go measure the cat on my 1990 Si, and well, it looks like the cat is welded to the b-pipe.
wtf. is that how they used to be from the factory? or was this a replacement job that was welded on?
Old Mar 1, 2006 | 09:28 PM
RCautoworks's Avatar
Default Re: OEM catalitic conv. on 90 Si - welded or bolted? (( o )( o ))
Replacement job.
Going to have to cut it off, reflange it. Not fun
Old Mar 2, 2006 | 01:35 AM
1QuikSOHCZC's Avatar
Default Re: OEM catalitic conv. on 90 Si - welded or bolted? (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Replacement job.
Going to have to cut it off, reflange it. Not fun</TD></TR></TABLE>
Old Mar 2, 2006 | 04:48 AM
purplecrx's Avatar
Yeah, that sucks. Gadda love when you find little hidden treats in your car. Just found out the guy w/ my SOHC ZC before me made a homemade keyway for the crank pulley. Now it has grinded away some material and has play on the crank. So now I get to put out some more money to fix it right.
But yeah, like the above person said, cut it and weld it. But this time weld a flange on!
EDIT: Noticed the quote in your signature. Haha. DEFINITELY relevant here.
Old Mar 2, 2006 | 05:11 AM
StorminMatt's Avatar
Default Re: (purplecrx)
If you don't have a welder, it might be cheaper and easier to just buy an unaltered pipe from a salvage yard.
Old Mar 2, 2006 | 07:39 AM
( o )( o )'s Avatar
Default Re: (StorminMatt)
good point! thanks for teh info guys.
umair
Sep 11, 2008 02:47 PM
kartman5
Honda Civic (2006 - 2015)
Aug 6, 2008 07:33 AM
Bulli Kid
13
May 15, 2008 06:49 PM
[Ennis_D]
Mar 13, 2006 01:14 PM
A D NOH
Sep 15, 2003 10:07 PM
