Best Engine/Engine Bay Cleaner
Old Mar 1, 2006 | 08:50 PM
Ash81's Avatar
Default Best Engine/Engine Bay Cleaner
what is the best cleaner or which one do you use to clean your engine/engine bay....post pics of before and after if you have some.
Old Mar 1, 2006 | 08:52 PM
ea_hatch's Avatar
simple green works pretty good
Old Mar 1, 2006 | 08:53 PM
dreww..'s Avatar
I use Simple Green as well
Old Mar 1, 2006 | 09:04 PM
prada_G's Avatar
Default Re: (dreww..)
a lot of people will say simple green, followed by a good spray down with tire shine foam .
Old Mar 1, 2006 | 09:42 PM
B2FiNiTY's Avatar
Default Re: (prada_G)
Gunk foaming engine degreaser
Old Mar 1, 2006 | 09:49 PM
5STAR3's Avatar
Default Re: (B2FiNiTY)
a hot pressure washer works well
Old Mar 1, 2006 | 10:13 PM
Mires's Avatar
Default Re: (5STAR3)
The car wash engine de-greaser. I don't have alot gunk buildup in my engine bay cause I use it often and it works great. If you have alot of buildup than Simple green. After that spray some tire shine on the engine and watch it bling.
Old Mar 1, 2006 | 11:58 PM
4genaccordfreak's Avatar
well.. if you are able to be hooked up with anything industrial.. we have used (Swish) FACTO PM23 industrial cleaner/degreaser at the shop on both customers and our own engine bays!! It is Acid/Alkaline based and absolutely works amazing on grease and grime..
although if you are going to use anything like that.. DO NOT leave it on too long on anything aluminum or electrical.. because it will eat it away.. PM23 and a Pressure Washer PWNS all!!
or if you just want something you can buy at any auto store.. anything citrus/acid based degreaser will work.. some higher strength cleaners can work.. but will need more than 2-3 applications and alot of "elbow grease"
Old Mar 2, 2006 | 12:17 AM
shockerjoe says's Avatar
Default Re: (4genaccordfreak)
get the engine nice and warmed up then shut her off and use simple green and water.
civycoop
13
Jan 9, 2007 11:00 AM
gosu08
Oct 20, 2006 11:43 PM
Civic Hybrid
May 15, 2006 09:24 AM
realmc
Aug 9, 2005 09:20 PM
beaterman
May 6, 2003 09:19 AM
