Need help with JG Edelbrock throttle body! ASAP
Old Mar 1, 2006 | 08:45 PM
mr_ek9's Avatar
Default Do JG Edelbrock throttle body just bolt up? HELP ASAP updated pictures
I have a JG Edelbrock 65mm type r TB, any body knows why this TB doesn't open all the way? I have the stock b16 and it opens all the all but some how the jg doesn't. Any help would be great.
Modified by mr_ek9 at 5:07 PM 3/2/2006
Modified by mr_ek9 at 3:32 PM 3/6/2006
Old Mar 2, 2006 | 07:49 PM
Marauder's Avatar
Default Re: Do JG Edelbrock throttle body just bolt up? HELP ASAP (mr_ek9)
Did you check the difference when the throttle cable is connected and you hold the throttle wide open?
Old Mar 3, 2006 | 04:32 PM
mr_ek9's Avatar
Default Re: Do JG Edelbrock throttle body just bolt up? HELP ASAP (Marauder)
I used the type r throttle bracket and the si and dx they all don't work. The JG only open 50%. T don't know what could be wrong?
Old Mar 4, 2006 | 10:14 AM
PURPLETERROR aka BIGMATT's Avatar
retardation possibly? i have installed 5 of these with no problems. Try posting a picture
Old Mar 6, 2006 | 02:22 PM
mr_ek9's Avatar
Default Re: Do JG Edelbrock throttle body just bolt up? HELP ASAP (PURPLETERROR aka BIGMATT)
Here's how it looks
Here's it is at full throttle
How it is hooked up
The stock b16
b16 opens all the way
The JG at full throttle
What's the problem here? need help?
Old Mar 6, 2006 | 03:29 PM
Marauder's Avatar
First, it looks like the cable isn't adjusted when the JG TB is bolted on, the cable looks loose, compared to the B16.
Will the JG TB open all the way by hand?
Old Mar 6, 2006 | 03:59 PM
mr_ek9's Avatar
The JG, I adjust it the throttle cable just like the b16. Yes, the JG opens all the way by hand. It's like throttle cable don't pull it enough to open all the way.
Look in the b16 the butterfly bracket, it is at an angle and the JG is stright up. That's why it's not pulling it open all the way. Why is that??
Old Mar 6, 2006 | 09:02 PM
QuangAlang's Avatar
jsut take out some of the slack in the cable???
Old Mar 7, 2006 | 10:14 AM
Marauder's Avatar
Default Re: (QuangAlang)
Cable looks loose.
Old Mar 7, 2006 | 11:56 AM
Dan Ruddock's Avatar
Default Re: (Marauder)
looking at the second pic looks like the larger butterfly is bottoming out on the un ported Im throat. Dan
Old Mar 7, 2006 | 12:02 PM
Default Re: Do JG Edelbrock throttle body just bolt up? HELP ASAP updated pictures (mr_ek9)
take the slack out of the throttle cable. I cant belive this isnt fixed yet
Old Mar 7, 2006 | 01:53 PM
methos713's Avatar
Default Re: Do JG Edelbrock throttle body just bolt up? HELP ASAP updated pictures (PURPLETERROR aka BIGMATT
looking at the pictures, your jg butterfly seem to look stuck at the intake manfold port...if you compare the b16 and jg insides...you will see that the jg butterfly looks bigger then the port. The b16 fits perfect though. Hope it helps.
Old Mar 7, 2006 | 02:41 PM
non-VTEC's Avatar
you need to take the intake manifold off and have the manifold opening bored out to match the throttle body size.
the throttle plate is getting caught on the opening of the manifold.
Old Mar 7, 2006 | 05:32 PM
mr_ek9's Avatar
Default Re: Do JG Edelbrock throttle body just bolt up? HELP ASAP updated pictures (non-VTEC)
The JG manifold is 65mm too, both of them are good.
I swap the throttle body butterfly bracket now it kinda works now it open like 80%,
I put the b16 on the JG it works better now but not all the way yet. Any way I can adjust the gas pedal? Or any other suggestions?
Old Mar 7, 2006 | 06:32 PM
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr_ek9 &raquo;</TD></TR><TR><TD CLASS="quote">
the inside of that manifold can't be 65mm. you can clearly see the the "lip" of that manifold.......when the throttle body/plate opens its hitting that thing so it will not open all the way..
seanc520
Mar 27, 2013 07:23 AM
Cpt Ben
Apr 5, 2007 07:18 PM
JeffBro
Jun 26, 2006 05:58 PM
