Change Throttle Body if Intake Manifold is Change???
Old Mar 1, 2006 | 08:34 PM
Fatty_1775's Avatar
Default Change Throttle Body if Intake Manifold is Change???
My friend has a second gen B16, high compression (cant remember exactly what), type r cams and is installing a skunk2 intake manifold. Question is, do you need to change the throttle body as well?
Old Mar 2, 2006 | 03:28 PM
DelSolDon's Avatar
Default Re: Change Throttle Body if Intake Manifold is Change??? (Fatty_1775)
you don't have to change the TB, but you will get a little turbulence from the inside lip of the throttle body if you don't. a cheap, but effective option is to send the stock throttle body to http://www.maxbore.com and for $100, he can bore the stock TB, machine a new throttle blade, and clean it all up for ya.
slide inside
Oct 21, 2009 01:15 AM
1baddturbosi
Feb 18, 2007 07:36 PM
Phatch99
Jun 10, 2004 07:14 AM
