Engine knocking
Old Mar 1, 2006 | 08:33 PM
novvti's Avatar
Default Engine knocking
I have a d15z1 and when i start it up sometimes, i can hear the engine knock and it tends to go away after it warms up. I just wanted to know if it was normal. BTW i use 93 octane gas.
Old Mar 1, 2006 | 08:42 PM
Civicse's Avatar
Default Re: Engine knocking (novvti)
just when its cold eh? sounds like piston slap. i'd do a leakdown test to see if everything is ok, and a compression test. why are you running 93 octane? unless you have like 12:1 compression you don't need that.
Old Mar 1, 2006 | 08:47 PM
novvti's Avatar
Default Re: Engine knocking (Civicse)
well the previous owner got the car use to 93 octane and i tried putting 91 and the motor started knocking pretty bad
Old Mar 1, 2006 | 08:49 PM
Civicse's Avatar
is the engine modded at all do you know? if it is then maybe your getting dtonation with the 91.
Old Mar 1, 2006 | 08:53 PM
novvti's Avatar
well it does have intake, 5 zigen exhaust, and test pipe, its using mobil 1 10w-30 full synthetic oil
Old Mar 1, 2006 | 08:54 PM
novvti's Avatar
whats weird is that the guy that had the car before put a 93 octane only sticker on the gas latch.
Old Mar 1, 2006 | 08:57 PM
Civicse's Avatar
the only reason to use high octane gas is if you have high compression. so unless he put high comp pistons it there or something i don't see why it needs 93 octane. i know from my expierience of putting 91 in my car, it seemed to run worse. like i said to some tests to see if anything is damaged
EliTe 93Lude
Jul 31, 2006 07:18 PM
pinoy369
15
Mar 2, 2006 10:39 PM
digitalh3lix
Dec 7, 2004 10:35 PM
explosive
Sep 8, 2004 12:54 PM
PearlWhiteAccord
Dec 11, 2003 12:13 PM
