Checkout this lug wrench
It has built-in torque settings of 90/105/120 Nm and uses 1/2 sockets. Cost of 6,980 yen (about $62 USD). I'm gonna order one for my tool collection this weekend.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazydragonclk »</TD></TR><TR><TD CLASS="quote">what does the torque settings mean?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dee »</TD></TR><TR><TD CLASS="quote">It has built-in torque settings of 90/105/120 Nm </TD></TR></TABLE>
1 newton meter (Nm) = 0.737 562 147 pound foot (lbft or ftlbs)
so the settings are 65 ft.lbs/77ft.lbs/88ft.lbs.
The advantage of such a design is it takes away any sideways moment or lateral force. It is a pure twisting force unlike a conventional wrench.
interesting wrench....i guess it makes it easier to just do one of the 3 adjustments rather then getting out the torque wrench and setting it. where do you get this from?
I will be ordering one this weekend. I'll let you kow how it is next week after it arrives. If it's a nice item I'll setup a groupbuy for you guys.
There's very little lateral force with a conventional torque wrench. (When was the last time a torque wrench did anything other than screw a lug nut on the way it's supposed to? I've never had that happen.) Also, if this wrench is a lot shorter than a conventional torque wrench (it's not entirely clear from the photos), then it offers less leverage, and requires more force.
For ten bucks, you can get one of these (click on photo for more info):
It even comes in a plastic case.
geez.. there always has to be a nay-sayer on H-T.
Yes, I already have a $75 torque wrench that is similar to the $10 Harbor freight item you posted but I like the convenience of the spinner function coupled to a torque wrench. This item was designed for quick tire changes when you do not have access to air powered tools (sunday racers)
No, there is not a lot. Say the average torque wrench is about 1.5" long? so 90 ft.lbs gives a lateral force about about 60 lbs if you used the end of the wrench. It's not a lot and the designers of your car anticipated people using a torque wrench. I was just make a "theoretical comment". The "safety" factors are so high in cars it really doesn't matter.
I remember engineers running into a problem with lateral forces and moments when using a torque wrench and multiplier at a telescope. However they were torquing to about 1500 ft.lbs and in some cases using about 3500 to get the nuts off. That's when it starts becoming an issue.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike C »</TD></TR><TR><TD CLASS="quote">200% more torque? We're looking for accuracy here... If you want more torque, get a longer lever.</TD></TR></TABLE>
Bingo. It's called a pipe, fits on the end of every wrench.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri »</TD></TR><TR><TD CLASS="quote">Bingo. It's called a pipe, fits on the end of every wrench.
lol yup, I will admit to having taken all of the batteries out of my MagLight and used that as well instead of a pipe.
</TD></TR></TABLE>lol yup, I will admit to having taken all of the batteries out of my MagLight and used that as well instead of a pipe.
It has built-in torque settings of 90/105/120 Nm and uses 1/2 sockets. Cost of 6,980 yen (about $62 USD). I'm gonna order one for my tool collection this weekend. </TD></TR></TABLE>
wow thats mad jdm
wow thats mad jdm
