94 hatch wit a b16 motor
wtf, what b16,a a2 a3 a1steaksauce? if its a usdm motor has to be a b16a2 wich is found in the 99-00 civic Si if its jdm then i dont know any of the above!
i believe the b16a1 came in the si-r and the a3 from what i thought was the delsol si vtec, but then again i could be 100% wrong here, i only deal with d-series
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 »</TD></TR><TR><TD CLASS="quote">i believe the b16a1 came in the si-r and the a3 from what i thought was the delsol si vtec, but then again i could be 100% wrong here, i only deal with d-series
lol, you are 100% wrong . . .
hatcheys (aka: eg's) weren't made in the US with a standard B16. There is 3 different version of the b16 found in USDM Cars. Del Sol DOHC(94-95: B16A3) and Del Sol (96-97: B16A2) <-- might have switched those up, but either way, you get the picture. AND, 99-00 Civic Si with a B16A2.
All USDM b16 OBD1 and OBD2 engines were rated at 160hp. JDM B16 obd-0, was rated at 165 hp and the obd1 and obd2 were rated at 170hp. Difference between the 3 is the fact that the OBD-O has the cable tranny while the newer version have the hydraulic.
</TD></TR></TABLE>lol, you are 100% wrong . . .
dailygirl
25
Jun 21, 2004 08:56 AM
Spade
15
May 29, 2002 02:31 PM
