Lowering my integra
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaTeg6 »</TD></TR><TR><TD CLASS="quote">You should be okay with only a 1.3" drop. I think the rule of thumb is 2.0" or lower is when you should look into a camber kit.</TD></TR></TABLE>
1.3" why not 1.75 front and 1.5 rear..good stance
i would put on a camber kit because if you are gonna be taking everything off anyways, it won't be that hard, and if your spings sag or anything even a slight negative camber will give you uneven wear -
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g0t vtec- »</TD></TR><TR><TD CLASS="quote">
1.3" why not 1.75 front and 1.5 rear..good stance</TD></TR></TABLE>
yea that is a good stance, looks real good without having to worry about tire rub... but is it necessary to get the car aligned with that small of a drop?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rkrone »</TD></TR><TR><TD CLASS="quote">i would put on a camber kit because if you are gonna be taking everything off anyways, it won't be that hard, and if your spings sag or anything even a slight negative camber will give you uneven wear - </TD></TR></TABLE>
if your going to buy and put a camber kit on, make sure its adjusted right! and get your **** aligned, my friend got it, and didn't to it right, and went through his brand new falken ezenis in like 2 months if not less
Guest
Posts: n/a
no matter what when you lower your car you need a camber kit because when you lower it you get camber but when you dont lower it that much like only an inch then the tire wear from the camber wont be so bad so you wont really have to worry about it.
Thanks for the help. i have 17 inch rims, that is why i only want it to lower this much. i was also thinking about doing 1.3 in the back and 1.5 in front.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DoctorGSR »</TD></TR><TR><TD CLASS="quote">toe causes the wear on the tires, not the camber. make sure you get it alligned regardless of how low you end up going.</TD></TR></TABLE>
Camber does cause wear and if you think it doesnt then you are pretty darn stupid... toe causes wear also but when you lower a car it usualy doesnt get tow in or out... it usualy doesnt get tow in or out untill you install the camber kit... thats when you need an alignment.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by four1one »</TD></TR><TR><TD CLASS="quote">
Camber does cause wear and if you think it doesnt then you are pretty darn stupid... toe causes wear also but when you lower a car it usualy doesnt get tow in or out... it usualy doesnt get tow in or out untill you install the camber kit... thats when you need an alignment.</TD></TR></TABLE>
first of all, its toe. second of all, go tell this to the people in the suspension forum and watch them laugh at you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lino_tegra »</TD></TR><TR><TD CLASS="quote">Thanks for the help. i have 17 inch rims, that is why i only want it to lower this much. i was also thinking about doing 1.3 in the back and 1.5 in front.
i had 17's on my old gsr and i looked great slammed about 2 inches in front and 1.75 in rear
my wear wasnt too bad as long as i got my toe adjusted every so often.
you should consider it.
my wear wasnt too bad as long as i got my toe adjusted every so often. you should consider it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by four1one »</TD></TR><TR><TD CLASS="quote">Camber does cause wear and if you think it doesnt then you are pretty darn stupid... toe causes wear also but when you lower a car it usualy doesnt get tow in or out... it usualy doesnt get tow in or out untill you install the camber kit... thats when you need an alignment.</TD></TR></TABLE>
Do some more research. If you a lower a Honda and do not get it aligned, the reason the tires wear so fast is mostly because the toe is out-of-spec, in addition to a little negative camber. The nature of 1990's Honda suspension geometry causes toe as well as camber to change as the suspension moves up and down. When the front suspension is lowered, the steering tie rods pull inwards and cause the front tires to toe out. This causes MAJOR tire wear if the front toe is not aligned properly.
Some negative camber is, in most cases, a good thing in terms of better handling and roadholding. Why do you think race cars run so much negative camber? Of course that much isn't suitable for street use. However I myself have never had a camber kit on my car, and I used to run as much as -2.7 degrees camber in the front, and was still able to get 30K+ miles out of a set of Yokohama ES100 tires. This is because I kept the toe settings in check and rotated my tires every 5K miles.
In most cases for street use, I wouldn't bother with a camber kit, unless you're running -2.5 camber or more, or unless you want to dial in specific settings for racing purposes.
In short, in the ~120K miles since I first lowered my car, I've worn through 3 sets of tires, and 1/2 way through a 4th set. Most of that time my car has always had -2 deg. camber or more, and has never had a camber kit. If you still think a camber kit is necessary well... it's your money to waste.
98k20ex
Sep 12, 2004 07:38 AM
The Internet Tough Guy
34
Oct 10, 2003 10:32 AM
