Glass and door handle removal help
Old Mar 1, 2006 | 02:18 PM
Rudaluda's Avatar
Default Glass and door handle removal help
Today i decided to see what i could do with removing these things. The glass is out of the bottom track the keeps it in the frame rails, i can move it up and down freely but i cant figure out to remove it from door. the handle i removed the 2 10mm bolts and a few of the rods, but i still cant get it out anymore ideas or sugeestion would be great, thnaks.
Accident occured so i swapped doors but id like to get the right lock and also the glass i want removed is tinted to match the rest of the car.
Old Mar 1, 2006 | 07:23 PM
M2B4's Avatar
Default Re: Glass and door handle removal help (Rudaluda)
the handle is very simple i had same deal took me 5 mins to switch out. 2 bolts and a couple clips. just look in there and youll see what to take off. everything is screw or pop off.
Old Mar 1, 2006 | 09:29 PM
SnlpeR's Avatar
theres a lot of work involved in removing the glass
roll window down
peel rubber strip on the rubber molding (its held on by thin dlb sided tape)
unscrew the 3 or 4 screws
remove that side rubber molding
peel off plastic on door
unbolt two 10mm bolts that the glass bolts to the regulator
i hope you have a 4th gen coz its instructions for it
hondaslave1342
Feb 6, 2019 04:07 PM
tallypbplayer
Mar 17, 2010 09:53 PM
AlphaKennyWun
10
Dec 28, 2009 07:41 PM
importfan85
Aug 20, 2008 07:30 PM
doughboixx
Jun 27, 2007 08:11 PM
