Tire wear...Out of nowhere. Toe or camber issue....or worse?
Doing a little work on my car, I noticed my tires were wearing out a little odd. Here's a picture of the tire...maybe someone can give me an analysis
Yokohama AVS es100
205-45-16
Drivers Side, Front Tire
Camber is at 1.2 degrees in the front, 1.4 in the rear
Modified by EnjoyTheRideDC2 at 4:17 PM 3/1/2006
Yokohama AVS es100
205-45-16
I assume by the tread pattern that is the inside of the tire?
Is your car dropped a lot? If it is on both sides and your car is dropped it is probably camber wear.
If it is just one side it looks like a "toe out" problem. Get an alignment.
anyone else?
anyone else?
There are many possible causes:
- camber wear due to lowering
- improper alignment
- suspension problem (e.g. worn bushings allowing the tie rods to wiggle back and forth slightly as you drive)
Have it aligned and/or put it up on a lift to inspect the suspension...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri »</TD></TR><TR><TD CLASS="quote">I assume by the tread pattern that is the inside of the tire?
anyone else?</TD></TR></TABLE>
Yeap, That is the inside of the tire...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pingaturbo »</TD></TR><TR><TD CLASS="quote">Where in cali you at??? If your in the North County area, bring it by my job!!</TD></TR></TABLE>
I appreciate the offer
, but unfortunately i'm in Southern California...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">There are many possible causes:
Which bushings should I be looking at, in particular? LCA? UCA?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joon Joon »</TD></TR><TR><TD CLASS="quote">wats the toe setting at?? and where in socal are u??</TD></TR></TABLE>
Have not recently checked the toe, but when I set it initially, it was at 0.4 in the front, 0.2 in the rear. I'm in the Pasadena Area.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">get an alignment.
it has nothing to do with your camber.</TD></TR></TABLE>
Awesome, thanks for the input.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbolshatch »</TD></TR><TR><TD CLASS="quote">get a alingment and check for loose and worn suspention components</TD></TR></TABLE>
Looks like thats the unanimous decision....alignment it is
