Suspension Squeeks
I have a 2000 Civic Sir. When I drive on normal pavement the car is fine. If I hit any bumps or rough stuff the car squeeks a little bit. Has anyone else had this problem?? What is it?? Thanks guys
Is your car dropped? Lowering springs? If not, then I would take a look at your bushings, which ever corner the noise is coming from.
Do you have anything Polyurethane under your car or on your suspension? That stuff is known to squeek. Good luck.
